'81 won't start
Old Mar 21, 2012 | 03:56 PM
sabre1981's Avatar
sabre1981
Default '81 won't start
A friend and I went to get my car out. I knew we'd have to jump it because it wouldn't turn over when I had tried prior. We hooked the jumper cables up, waited for a few and then tried to start it. It almost turned over, but didn't so I waited another few seconds and gave it another try. It turned over and almost started. Gave it a third try and got nothing. No click, no radio, no windows, nothing...it was as if the battery wasn't even hooked up. Pulled the battery out and took it to a parts store. They tested it and it was low, but good, so they charged it and it got a good charge. Double checked the connections at the battery and starter and they were good. While the ground looked good, tomorrow I'll pull it from the frame and see how it really looks. A few people have mentioned something about an inline fuse on the positive line, does the '81 have something like that? Anyone have other thoughts/ideas?
Old Mar 22, 2012 | 09:30 AM
Crash80's Avatar
Crash80
There is a fusible link at the starter solenoid. If that is toast, you will not get power. You can pick those up at your local parts house.
Old Mar 22, 2012 | 12:21 PM
larryg3's Avatar
larryg3
since all the power is out I would say it is the fusible link.
here is a picture I just replaced the entire harness.
Old Mar 22, 2012 | 02:17 PM
81$$pit's Avatar
81$$pit
I am having the same issue with mine, also have a draw that sucks the battery dead in 2-3 days and slow starting when especially when hot.
Old Mar 22, 2012 | 11:28 PM
sabre1981's Avatar
sabre1981
It is the fusible link. Got a replacement from my mechanic and will work on it next week sometime.
Old Mar 23, 2012 | 09:11 AM
81$$pit's Avatar
81$$pit
how did you narrow it down to that?
I am hoping my co working brings in a amp tester today so I can try and trace mine down but I have never used one.
Not looking forward to crawling under this thing again.
Old Mar 23, 2012 | 07:57 PM
sabre1981's Avatar
sabre1981
Checked the ground on the battery and it was good, so moved up to the starter. Started poking around and got a spark from an exposed wire, so I knew there was power going to the starter. After unplugging the the power from the battery, went back to the exposed wire and discovered it wasn't just exposed, but broken in half. Took a picture of the area and my mechanic confirmed it was the fusible link.
Old Mar 24, 2012 | 01:43 PM
81$$pit's Avatar
81$$pit
figured it out, I took of the heat sheild started testing resistance wiggled the wire with plastic thing on it and pow! the radio came on and I could crank it over.
I ordered the whole harnes from MID America for 89.00 + shipping and tax.
Old Mar 24, 2012 | 08:30 PM
sabre1981's Avatar
sabre1981
Glad you solved yours
To '81 won't start
