mystery alt wire?
Old Mar 21, 2012 | 05:58 PM
jman1's Avatar
jman1
Default mystery alt wire?
the wire that connects to the top post on the back of the alt broke... as i unwrapped the wires so i could replace the end i found another wire... looks like an 8 or 10 gauge wire.. same guage as the one that goes to the post.... any ideas?
Old Mar 21, 2012 | 06:03 PM
Mark Riles's Avatar
Mark Riles
Color of said wire would be very helpful to us.
Old Mar 21, 2012 | 06:34 PM
jman1's Avatar
jman1
its black...
Old Mar 21, 2012 | 06:53 PM
my 76 ray's Avatar
my 76 ray
My '74 has a black wire that grounds the alternator case.
Old Mar 21, 2012 | 07:01 PM
jman1's Avatar
jman1
my alt has 2 thinner wires going into a white connector... 1 thinner wire to the bottom of the alt looks like a ground... a thicker wire to the post terminal and the same color and thickness wire with no where to go.....
Old Mar 21, 2012 | 09:17 PM
Tim H's Avatar
Tim H
Anything black is a ground probably?
My alt has a black ground wire running off it to ??? but being a vette you can't have too many grounds!!!
Old Mar 22, 2012 | 03:18 PM
jman1's Avatar
jman1
Ok... My bad... The wire is red... Same thickness and color as the one connected to the post on the back of the alt... And very much has juice to it!!! I touched it to the case of the alt and ZAP!
Old Mar 22, 2012 | 03:44 PM
MelWff's Avatar
MelWff
did it break off the white connector on the side of the case?
Old Mar 22, 2012 | 04:06 PM
jman1's Avatar
jman1
Nope.. The wire that goes to the post broke... When I unwraped the wires to get at it.. I found it hidden... Its live!! But was not connected to anything and the car was running fine... Over a year I have had it
Old Mar 22, 2012 | 07:10 PM
speedreed8's Avatar
speedreed8
its possible a PO ran a new alternator wire to starter and left the old one. or there's also a wire for the underhood light that ties into the alt. + wire. someone may have wrapped it up in the harness. just some ideas.
Old Mar 22, 2012 | 07:37 PM
jman1's Avatar
jman1
what bugs me is its a live wire... and its like 8 or 10ga... same as the gauge on the post of the alt.... im gonna have to trace it back cause its gonna bug me...
Old Mar 23, 2012 | 06:19 PM
Alan 71's Avatar
Alan 71
Hi j,
Is this any help?
Regards,
Alan
Old Mar 23, 2012 | 07:45 PM
jman1's Avatar
jman1
i have 2 of those red wires... both live... one was hooked up and one was taped up....
Old Mar 24, 2012 | 05:54 PM
msandym's Avatar
msandym
Default mystery alt
mine is like that . could the other wire have anything to do with guage ?
Old Mar 24, 2012 | 07:21 PM
jman1's Avatar
jman1
do you have both wires hooked up??
Old Mar 24, 2012 | 08:41 PM
Peterbuilt's Avatar
Peterbuilt
Default Does this help?
http://www.nrjvette.com/johdotukset/...tte%201977.pdf
To mystery alt wire?
