belts
Old Mar 22, 2012 | 10:18 AM
mrpacecar's Avatar
mrpacecar
Default belts
can any one tell me the gm numbers for power streeing belt---air-cond belt--alternator belt-- smog pump belt. for a 1978 corvette pace car L-82 with auto. thaks
Old Mar 22, 2012 | 03:49 PM
MelWff's Avatar
MelWff
why do you need the original GM numbers?
Old Mar 22, 2012 | 03:59 PM
mrpacecar's Avatar
mrpacecar
Default belts
i am trying to keep it all original it only 20,325 miles
Old Mar 22, 2012 | 04:03 PM
mrpacecar's Avatar
mrpacecar
just want to keep it all original 20,325 miles
Old Mar 22, 2012 | 04:12 PM
MelWff's Avatar
MelWff
You do realize GM supercedes numbers over a period of 34 years. Paragon lists some of the numbers
https://www.paragoncorvette.com/sear...earchTerm=belt
Old Mar 22, 2012 | 05:35 PM
hunt4cleanair's Avatar
hunt4cleanair
Assuming you have A/C but than that was base with RPO Z78 (Pace Car)
A.I.R. 9433616 AS
Alt 9433656 CJ
A/C 9433916 PE
I use Quanta that prints the part number and date code (quarter) on the belt. Check them out...I've gotten all my belts from them and have a new set in the back room for a Pace Car L82 M21.
Old Mar 22, 2012 | 07:39 PM
BKarol's Avatar
BKarol
If you are going to continue to make sure the parts are correct, you might want to consider buying a 78-79 Judging Manual at NCRS.org.
http://www.ncrs.org/shop/index.php?m...roducts_id=217
Loaded with part numbers, paint, engine codes,etc.
Just an fyi.
To belts
