Cant Open Hood!!
Old Mar 23, 2012 | 08:08 AM
KROHN27's Avatar
KROHN27
Default Cant Open Hood!!
Hey guys,
Ive been in the C5 world for the last 5 years or so and just bought a '76. I brought it home and the hood release cable snapped in half. Any way to get the hood open without dismantling the whole front end?
Thanks!
Old Mar 23, 2012 | 08:15 AM
Mark Riles's Avatar
Mark Riles
Originally Posted by KROHN27
Hey guys,
Thanks!
Luckily on a '76 the cable that actuates both latches is on the firewall. Assuming that cable is still connected to both latches you just need to reach the latch on the driver's side. There are several ways you can achieve this. First, you can remove the splash plate from the underside of the driver's side and reach up between the washer tank and brake booster and try to manually actuate the latch. This can be difficult. In the wiper trough on the driver's side there is a rubber plug that can be removed and a long screw driver can be fed in to push on the latch and release them.
Old Mar 23, 2012 | 09:43 AM
KROHN27's Avatar
KROHN27
I'll give it a shot!
Thanks!!
Old Mar 23, 2012 | 10:07 AM
czardali's Avatar
czardali
If the passenger side is elevated there is also a rubber plug you can push out and push with a screw driver. I did it with my finger and it released just fine.
Old Mar 23, 2012 | 10:46 AM
bluthundr's Avatar
bluthundr
http://www.mamotorworks.com/corvette...-320-3852.html
Old May 20, 2012 | 10:42 AM
KenSny's Avatar
KenSny
All good suggestions.
After struggling with my hood a couple of years ago I used a similar idea of the "emergency pull cable" given in one of the previous links. It is tucked up under the dash for future use.
Of course not that I'm ready for the next time, it will probably never happen again.
Old May 23, 2012 | 07:29 PM
travelerbob's Avatar
travelerbob
Me too, on my 79, I bought 2 diff. replacement cables for the broken one and neather one fit. One cable works both latches and if it breaks at least one latch will be stuck shut. Had to alter them then added emergency cable to each side. One stayed in wiper trough below whindshield the other one had to go under left front fender behind wheel well (because of the direction lever works.)
Old May 24, 2012 | 01:04 AM
john roth's Avatar
john roth
I had the same problem, over and over. I replaced the hood latches with magnets. My hood is an L88 so I have a hand hold to open it but Iwon't have a stuck hood again.
Old May 24, 2012 | 02:54 AM
bluedawg's Avatar
bluedawg
Anyone ever use hood pins, I've thought about it but haven't gotten that far.
Old May 26, 2012 | 09:39 PM
john roth's Avatar
john roth
http://forums.corvetteforum.com/c3-g...d-magnets.html
Old May 27, 2012 | 08:31 AM
Mark Riles's Avatar
Mark Riles
I think pins are the next best thing to the stock latches but you lose the security of keeping others out of your engine compartment. I have always wanted to design a central latch of sorts so there is only one latch to line up, one cable, and one access point for emergency hoop opening.
Old May 27, 2012 | 09:32 AM
Big Block 69's Avatar
Big Block 69
After my 3rd cable broke, I went with hood pins. The other methods all work, reaching up from underneath, loosening hood hinges,etc. but if there is something like a carb fire or another reason you need to raise the hood NOW, The hood pins were best for me.
I installed my hood pins yesterday and it was by far the easiest thing I have ever done to this car. These pins are threaded the same as the spring latches and screwed right into place. The hardest part was drilling into the L88 hood, but it is done and I think it looks great.
To Cant Open Hood!!
