1976 Alarm Questions
Old Mar 25, 2012 | 01:23 AM
1986coupe's Avatar
1986coupe
Default 1976 Alarm Questions
A PO had taken the alarm key switch off of the side of the car...that shaved look. Thankfully the wires and the switch are there. I have the measurements from another member of where to put it. I was looking at another 1976 Corvette today and noticed that there is supposed to be a bracket on the inside of the drivers side fender. I have been looking everywhere to see what this bracket it called and where to possibly get one so that I can get this done. Any ideas?
Old Mar 25, 2012 | 01:29 AM
oldalaskaman's Avatar
oldalaskaman
alarm lock bezel
http://www.google.com/url?sa=t&rct=j...ym1lR5X-iIrQ0g
https://www.paragoncorvette.com/p-35...h-bracket.aspx
Old Mar 25, 2012 | 01:32 AM
1986coupe's Avatar
1986coupe
Sorry but that isn't the part that I am thinking of. It looks like a bracket or "shelf" that appears to have adhesive holding it to the side of the fender just below the washer fluid container.
Old Mar 25, 2012 | 01:43 AM
oldalaskaman
I found that one also , but they only had the one, sorry
Old Mar 25, 2012 | 09:43 AM
Peterbuilt's Avatar
Peterbuilt
Hi Bill,
Is the shield the part that you need?
Regards Pete.
Old Jun 20, 2012 | 12:20 AM
scf100's Avatar
scf100
bringing this thread back as the alarm does not work on my 74........
it is missing the switched labeled A in pic above but more important its missing the engine wire harness......
where does that wire tie into?........where can I get that wire?
thanks,
Old Jun 20, 2012 | 12:35 AM
Peterbuilt's Avatar
Peterbuilt
The switch is the same one that is used on the headlight doors.
http://willcoxcorvette.com/product_i...ducts_id=24163
Not sure about the harness.
Old Jun 20, 2012 | 06:37 AM
scf100's Avatar
scf100
yea say the swith is same but wondering what the heck happened to lead wire.....
where to get one and where it goes?
Old Jun 20, 2012 | 09:56 AM
Peterbuilt's Avatar
Peterbuilt
Here's the pigtail connector for the little switch
http://willcoxcorvette.com/product_i...ducts_id=26186
Schematic
Old Jun 20, 2012 | 10:24 AM
scf100's Avatar
scf100
Thanks!
To 1976 Alarm Questions
