Am I screwed, alignment?
Old Jun 18, 2012 | 05:04 PM
Lt1er's Avatar
Lt1er
Default Am I screwed, alignment?
My frame is not rusty or cracked. But when I picked up my car with new tires and an alignment the guy told me and showed me that he could only get -0.2 camber on the right front. It has no spacer on the passenger forward A-arm.
The tech said that it appears that the upper arm is pushed in over the years. His advice was find a framing body shop that can pull it back out.
Any ideas of what else to try?
Old Jun 18, 2012 | 05:37 PM
Dustup7T2's Avatar
Dustup7T2
Terrorizing Orange Cones
IIRC, these spreader bars help to prevent the upper A-arm towers to stress inward.
Here's just one example (there are various flavors available from several vendors, depending on your needs):
http://www.ecklerscorvette.com/corve...1963-1982.html
Outside of a shop that can straighten frames, this may offer a solution and after installing one, would want to conduct another alignment. Might offer some help to return some of the camber angle more to the positive side.
Old Jun 18, 2012 | 05:46 PM
resdoggie's Avatar
resdoggie
Had a 1976 L-82, 4-sp
Royal Canadian Navy
Is the movement of the towers a result of metal fatigue or corrosion or both? Trying to decide if I should invest in one. Can you get one that is all bolt on?
Old Jun 18, 2012 | 05:48 PM
zwede's Avatar
zwede
The front x-member & spring towers have collapsed a bit. No biggie. As mentioned, get a spreader bar to avoid further deterioration.
You don't really want the factory alignment anyway. It was designed by lawyers.
Set the front to -0.7 dgr camber and as much caster as possible.
Old Jun 18, 2012 | 06:13 PM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
It could be a result of corrosion, depending on where a car spent most of it's life. Assuming it's not because of rust issues, it's generally a case where the weight of the engine, combined with the loads from the suspension, have caused a 30+ year old frame to "sag".
Yes a "spreader bar" could help. However, I would buy one directly from the source, 'Vette Brakes and Products. Eckler's simply buys VB&P stuff, re-boxes it, and frequently tacks on another 10-15% to the price....
Old Jun 18, 2012 | 07:09 PM
JimT's Avatar
JimT
I have the same problem on my '72 - my mechanic friend (works on race cars) says the same thing. The front end is slowly tilting inward. He's aligned mine as best he could and it still drives great - no unusual tire wear. I may purchase the spreader bar but I would like to see a picture of one installed.
Old Jun 18, 2012 | 07:26 PM
Paul L's Avatar
Paul L
OK.
Old Jun 18, 2012 | 08:33 PM
JimT's Avatar
JimT
Thanks! Looks good, I may just have to do this. Any hints for installation?
Old Jun 18, 2012 | 08:46 PM
Lt1er's Avatar
Lt1er
Hey thanks guys. This is a Nevada desert car that is parked on stands all winter. No rust here.
I will shop VB&P for a spreader with mechanical fan.
I saw that they have U-weld and welded. I would preferr the welded up already
Old Jun 18, 2012 | 08:53 PM
aussiejohn's Avatar
aussiejohn
Default What is the factory measurement?
G'day,
I hope I'm not hijacking, but it would be good to know the FACTORY dimension of the gap between the upper A arm mounting flanges. If such a figure was available, then it would be a simple measurement to let you know how far off stock it was.
Then you could insert a spreader bar and adjust it to bring it back to the factory dimension, lock it in and get a new alignment.
Anyone have these dimensions? Jim Shea?
Regards from Down Under.
aussiejohn
Old Jun 18, 2012 | 09:01 PM
biscuitville's Avatar
biscuitville
You may actually want to get the spreader bar that you need to weld up. If you still have the factory fan, clearance is a little bit of an issue and the ability to weld it exactly where you want it is helpful.
Old Jun 18, 2012 | 09:03 PM
biscuitville
Default distance
I copied this off a post when I decided to go with a spreader bar. Sorry, I don't remember who posted this originally. Hope this is helpful.
The distance between the shock absorber towers should be exactly 26 3/8", measured from where the front A-arm stud
protrudes through the shock absorber tower.
Old Jun 18, 2012 | 09:06 PM
Lt1er's Avatar
Lt1er
I will get the weldup then and get my buddy to weld it.
Old Jun 19, 2012 | 01:22 PM
cottoneg's Avatar
cottoneg
Actually I thought this was a known issue. I had the same issue. I wanted more caster and camber and they could not fit enough shim in to get the specs I wanted. I have two suggestions.
Suggestion #1: Take out the studs that hold the upper control arm in. They are a press fit and mine came out without too much trouble. Replace them with longer studs. Wheel studs that are ½ heavy duty for racing work well. Just measure the knurl size.
Suggestion #2 is probably not one you want, unless you run the car in time trial or race. They sell steel bushings. The upper bushing is drilled eccentrically so major adjustments can be made by turning the bushings and fine adjustments with a minimum of shims. This worked well for me.
http://www.guldstrand.com/scripts/pr...p?idproduct=94
Old Jun 19, 2012 | 03:13 PM
zwede's Avatar
zwede
The OP has the opposite problem. Even with no shims he can not get the positive camber that the factory alignment calls for.
Like I said in my previous post the factory alignment stinks, but some still want it anyway.
Old Jun 19, 2012 | 03:54 PM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
Good discussion already. FWIW, installing a spreader bar is one of the best things any C3 owner can do, frame issues or not. Many a later car came with them. As mentioned, factory alignment specs aren't necessarily what you need anyway. I'd install the spreader and get a precision (minimal/no tolerance, & symmetrical) alignment using specs such as those recommended by VBP. Not sure I'd try to press the towers all the way back to spec with the spreader (some pre-load is desirable), but you will notice that it reduces front end chassis flex. And, unless you've some serious frame issues I certainly wouldn't sweat a little neg front camber, as you may well find it to your liking anyway.
TSW
Old Jun 19, 2012 | 07:51 PM
cottoneg's Avatar
cottoneg
He said:
“he could only get -0.2 camber on the right front".
My interpretation of that was he wanted more negative camber like ½ to 1 degree negative. You would not want positive camber, but you would want positive castor. I was unaware the factory called for positive camber.
I was not sure what this meant:
“It has no spacer on the passenger forward A-arm.”
If there were no shims (spacer?), adding shims would have made more negative camber.
Either way, the spreader bar is a great idea.
To Am I screwed, alignment?
Old Jun 19, 2012 | 11:43 PM
Lt1er's Avatar
Lt1er
ZWEDE, You got me thinking........... Right on the paper work I requested .5 negative and as much castor as possible. The tech is telling me that even with no shim on the upper front all he can get is neg .2 so he tells me my front is bent in on the right front because the left front has 3 shims to match the .2 neg camber.
So just now I go out in the garage and if you add shims it moves the upper arm in causing additional neg camber. So the dumb Sh#t was trying to give me positive camber. I ordered a spreader bar today and if I spread the frame it would cause additional positive camber.
am I thinking correctly before I go back and raise some hell?
Old Jun 19, 2012 | 11:59 PM
JohnRR's Avatar
JohnRR
Yes, you are thinking correctly. The spreader bar will push the frame outwards which will give you more positive camber. You will correct this by adding shims on the upper control arm which will bring the arm back in towards the car centerline.
John
Old Jun 20, 2012 | 12:01 AM
Lt1er's Avatar
Lt1er
I got the print out Les Schwab gave me. The before was:
LF camber -.7 RF camber -.6 I ask to change to -.5
castor 3.84 3.74 I ask for as much as possible
toe in .25 degrees .29 degrees which is like in less than 1/16th
The specific range on the printout is 0-1.5 pos.
So he set it down as low as he could at -.2 and wanted me to bend the frame out to get that positive value
Then the after castor is 2.5 on both sides
I'm going back tomorrow.
