Am I screwed, alignment?
Old Jun 20, 2012 | 07:13 AM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
Originally Posted by Lt1er
I got the print out Les Schwab gave me. The before was:
LF camber -.7 RF camber -.6 I ask to change to -.5
castor 3.84 3.74 I ask for as much as possible
toe in .25 degrees .29 degrees which is like in less than 1/16th
The specific range on the printout is 0-1.5 pos.
So he set it down as low as he could at -.2 and wanted me to bend the frame out to get that positive value
Then the after castor is 2.5 on both sides
I'm going back tomorrow.
Are you sure you want to do that????
The problem that owners of older cars, such as C-3s, face, is that a lot of the techs today have never had to align a car that uses shims, rather than eccentrics, to set the caster/camber. They're used to simply loosening a nut, and turning the eccentric until...BINGO... the alignment machine's screen lights up "green". In your case, the guy didn't understand that he had to ADD shims, to pull in the a-arm, to ADD negative camber....
Old Jun 20, 2012 | 07:59 AM
Lt1er's Avatar
Lt1er
I know I know............ Actually I'm going to call first and say that my alignment was not what I requested and the tech was trying to do some book alignment. I have to wait for my VB&P spreader bar to arrive and get it in befor I go back.
Old Jun 20, 2012 | 12:04 PM
tfi racing's Avatar
tfi racing
98% of mechanics have no idea what caster or camber actually is and how they relate to higher performance handling,they are just "set the toe and let her go" robots obeying the magical mystery machine...If you like the "feel" of the car with those settings,I would just drive it and move on to your next task.
