Inductive pickup
Old Mar 25, 2012 | 10:24 PM
TOM B1's Avatar
TOM B1
Default Inductive pickup
In my F.A.S.T. ECU fuel injection kit there is a Inductive pickup harness. IPU for short. I want to buy a MSD distributor, are all MSD distrubutors the IPU style... is this what they call a magnetic trigger. Im confused here.
Old Mar 26, 2012 | 02:25 AM
oldalaskaman's Avatar
oldalaskaman
look for a member over in C4 tech. named Dr. Huxtable, He's installing the FAST on a C4 and his thread with pictures and others who've done that conversion are excellent.
hope this helps
http://forums.corvetteforum.com/c4-t...t-classic.html
Old Mar 26, 2012 | 10:40 AM
MrForce's Avatar
MrForce
St. Jude Donor '11, '14
mag trigger and IPU mean and are the same thing. Almost all MSD dizzys are mag trigger and will work. That said, you should probably look at the FAST dual sync as it has a number of advantages. Give me a call at 305-235-6160 if you need more help
Rob
Force Fuel Injection
Old Mar 26, 2012 | 09:48 PM
TOM B1's Avatar
TOM B1
Ok that clears that up, thanks to both of you.
On the duel sync, I will be installing a digital dash from Nordskog, I read a thread that crank triggers and duel syncs will interfere with them.
To Inductive pickup
