ENGINE ID # HELP!
Old May 17, 2002 | 04:18 PM
madmaxgt's Avatar
madmaxgt
Default ENGINE ID # HELP!
I was certain that I had the original engine in my 75, now im not so sure. My block is stamped V0508TAX Can some one tell me what I got?
Old May 17, 2002 | 05:33 PM
73-454's Avatar
73-454
Default Re: ENGINE ID # HELP! (madmaxgt)
I Believe your last 4 or 5 digits on the engine block must be the same as your Vin number. I hope you dont get caught-up with the numbers matching crap Just enjoy your vette
Old May 17, 2002 | 06:30 PM
tnt76vette's Avatar
tnt76vette
Default Re: ENGINE ID # HELP! (73-454)
Only Block # listed in Corvette Black Book for a '75 is: 3970010. Dont "sweat it" would be my advice....#'s matching rubber bumpers (which I have by the way, so pleeze dont :mad me) arent going to ever be worth as much as earlier ones........ :seeya
Old May 17, 2002 | 06:45 PM
BSiegPaint's Avatar
BSiegPaint
St. Jude Donor '06-'07
You've got a 70-72 Chevy C-10 255 hp truck engine. V=Flint, 0508= May 8 (production day) TAX designates a block for a 70 or 72 C10 or 3500 series 255 hp truck.
Now go have fun with it! :yesnod:
Old May 17, 2002 | 06:49 PM
BSiegPaint's Avatar
BSiegPaint
I believe if you want to have a "correct" engine, you'll need to find a block with suffix CHB if you havean automatic or CHA if you have a stick. If I remember correctly CHC was the L-82. Someone correct me if I'm wrong here.
Old May 17, 2002 | 06:51 PM
madmaxgt's Avatar
madmaxgt
No I don't! Actually I was hoping it was a better block (HP ETC.) The 75 L-48 was the lowest HP at 165! Thanks
Old May 17, 2002 | 10:33 PM
73-454's Avatar
73-454
Note: GM installed the best and the stongest blocks in the trucks. In the good old days it was quite common to pull out a vette or car engine and install a truck engine. The real hard core guys even pulled out the vette rear ends and replaced them with solid axels. Remember guys the C3's were real dogs we used them as chick magnets and they depreciated less then other new cars.
To ENGINE ID # HELP!
