Borgeson Conversion Kit
Old Mar 27, 2012 | 07:22 PM
Tom Huntoon's Avatar
Tom Huntoon
Default Borgeson Conversion Kit
I just ordered the manual to power steering kit for my 69. The kit says complete. I"m skeptical. I have double crank pulley. Do I need a triple? Anything else ? Thanks
Old Mar 27, 2012 | 11:09 PM
CheezMoe's Avatar
CheezMoe
St. Jude Donor '11-'12-'13,'19-'20
Assuming No A/C, double pulley is fine. Are the suplying pump and pump pulley as well? If not, be sure to get the right pump pulley to match your year and setup. The first one I got from ZIP gave us alignment fits until we figured out it was simply the incorrect part. (My bad, not Zips)
Assuming the kit has hoses and rag joint, you should be good to go. Good luck. This is an awesome upgrade!
Old Mar 27, 2012 | 11:36 PM
aussiejohn's Avatar
aussiejohn
Regards from Down Under.
aussiejohn
To Borgeson Conversion Kit
