Fuel tank venting needed?
Old Mar 29, 2012 | 10:53 AM
harveyhalabookie's Avatar
harveyhalabookie
Default Fuel tank venting needed?
OK, I previously put an Edelbrock carb and performer manifold on my '79. I am now doing suspension and brakes and decided to change the fuel lines along with the brake lines.
I installed a Holley mechanical fuel pump that does not require a regulator or return line. I ran -6AN braided hose from the tank to the pump and pump to filter/carb. I removed the evap cannister and return line.
My question now is what do I do with the openings on top of the gas tank (the old return inlet, and the tee and inlet for the evap cannister)? Can I just cap them off or does the tank need to be vented somehow? On all my previous cars I ran an electric fuel pump with a return line and no vent. Oh yeah, I also have a Stant locking gas cap. Thanks in advance!
Old Mar 29, 2012 | 11:03 AM
oldalaskaman's Avatar
oldalaskaman
leave the evap.open, close the return
Old Mar 29, 2012 | 11:45 AM
Mashman's Avatar
Mashman
Or, if you decide to block off the evap lines, you need to make sure you are using a vented cap.
Old Mar 29, 2012 | 11:54 AM
Mike Ward's Avatar
Mike Ward
Not to be nasty, but I guess I'll never understand why people strip stuff off their cars that help it operate properly.
Harvey- the return line from the fuel pump was there to eliminate the possibility of vapour lock. C3s are prone to this especially with hot weather and possibly some brands of E10 fuel. The evap canister weighs very little and eliminates the 'stinky car in the garage' issue as well as provides a vent for the gas tank.
Old Mar 29, 2012 | 12:37 PM
harveyhalabookie
Thanks for the input. I will block off the return and the tee-fitting for the evap line, but leave open the evap fitting at the sending unit.
Mike, thanks for the info, but I am doing a resto-mod and I am using the space for ignition box and other upgrades. Cheers.
Old May 30, 2013 | 06:02 PM
pawpaws toy's Avatar
pawpaws toy
After your modifications, you will need a vented cap. Drill a vent hole in the old cap. If you ever go back to stock, replace it.
Old Jun 4, 2013 | 08:55 PM
tektrans's Avatar
tektrans
Vented cap and or leaving the evap line open will work to vent but if you keep the car inside (which I assume you do) you may get nasty fumes in the garage.
To Fuel tank venting needed?
