Differences in a 75 to 81 frame?
Old Mar 29, 2012 | 08:46 PM
j6508398's Avatar
j6508398
Default Differences in a 75 to 81 frame?
I know the rear suspension is different but are the body mounts in the same location? I came across a very nice 75 4 speed rolling frame today. I would like to swap out to the pre 80 suspension, But if possible use the whole frame.. Thanks
Old Mar 29, 2012 | 09:49 PM
CaseyJones's Avatar
CaseyJones
St. Jude Donor '15-'16
I posed the same question to the forum recently and, if I remember correctly, the mounts work out in all the right places. The only significant difference is the crossmember for the differential mounting.
Old Mar 30, 2012 | 12:13 AM
63mako's Avatar
63mako
St. Jude Donor '08-'09
Here you go.
http://www.71corvette.com/frames.html
Old Mar 30, 2012 | 08:32 PM
holley505's Avatar
holley505
Crossmembers are different I do believe...
Old Mar 31, 2012 | 10:35 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by 63mako
Rear half of the frame is also different to allow for fuel tank position under the big back window.
To Differences in a 75 to 81 frame?
