A/C broke!!!
Thankfully the tool that you need for putting a vacuum on the system is available at Harbor Freight. Use that with a compressor.
Or, take it to a shop that can do this.
If you have no leaks you can change out the clutch but if you look at the price of the clutch it really is more cost effective to buy a rebuilt compressor from some place like Advance or Autozone. You could check e-bay or your favorite Corvette supplier.
If the system can hold a vacuum then release the pressure and then make sure to clean it out properly if you are going to retro fit it to R134A..but that is another topic.
If the comp clutch is bad, then chances are the comp isn't far off. They weren't the greatest to start with. I wouldn't waste time and money with it.
To convert to 134, changing hoses is recommended, as well as a modern condenser.
You can vacuum the system and fill with nitrogen and see if it holds a charge.
If you use 12 and loose it, then that can add up pretty quickly too.
I would suggest for 134, updating the compressor, changing condenser and hoses to suit and you should have a well operating system.
or
Update compressor, flush and use 12.
I guess you should really decide if you really want air first, it costs one way or the other.
Much cheaper then replacing original parts.
