78 interior heat
Old Apr 4, 2012 | 08:21 AM
ocala78pacecar's Avatar
ocala78pacecar
Default 78 interior heat
After reading all the posting on the forum about the different way members have address this issues, this is what I am going to try. First a new gasket on the rear of the hood, I am also going to put a cover over the windshield well, and last I am going to run manifold vacumn to the A/C hot water shut off valve. The valve is closed with manifold vacumn thru the cut off switch, so what would be different between that and another cutoff valve on the same hose? I am putting this out for input or reason not to do it this way. Thanks Jerry
Old Apr 4, 2012 | 08:34 AM
Mark Riles's Avatar
Mark Riles
Don't forget the foam block that goes around the top of the transmission case under the tunnel. It keeps hot air from flowing down between the transmission and the body. That piece of foam alone makes a huge difference.
Old Apr 4, 2012 | 08:59 AM
BTAL's Avatar
BTAL
St. Jude Donor '09
In doing the hydroboost/borgeson mod, I found the rubber boot covering the clutch rod going through the firewall was completely shot. This left an ~2" open hole directly from the engine bay into the cabin. Replacement from Zip was $22 with shipping.
Just something else to look for, at least in manual trans cars.
Old Apr 4, 2012 | 09:26 AM
jcloving's Avatar
jcloving
Check your speedo cable grommet too. Mine was missing. 1" hole open behind Ex. manifold.
I recommend putting down hushmat (or similar) and reflectix. They made a huge difference for me. Plus, I put in a real shut off valve on the heater core line.
Old Apr 4, 2012 | 09:57 AM
08vycpe's Avatar
08vycpe
There is no advantage to adding a second water cut off valve. I would not put a cover over the wiper valley if you have the rear hood seal. It would be worth while to put a vacuum guage on the hose to the water valve. Then, move the temp switch all the way to the left (cold) and see if you can maintain vacuum. Just driving around a bit can vibrate the temp lever ever so slightly to the right off of full cold and you can loose your vacuum. There is a cable adjustment turnbuckle behind the right lower dash cover if you need to adjust.
Without spending much money the best things you can do is:
Install the foam tunnel collar as suggested ($15.00)
Assure the seals around the vents in the kick panel are sealing and not leaking hot air.
Rear hood seal
proper operation of the water valve shut off
Make sure all openings through the firewall are sealed
Make sure the heat shield under the car in the tunnel is not missing
After that you have to start spending money for things like Dynamat under the carpet.
Old Apr 4, 2012 | 02:45 PM
ocala78pacecar
Thanks for all the inputs. I just replaced the carpet and I put the insulation kit in the car at that time. The only heat that is coming into the car is from the vent and just a little heat thru the firewall as a hold, not anyone place. The foam tunnel collar is installed and the heat shield is under the car. I will check the kick panel next. I checked the AIM and the vacumn hose diagram and it looks like the cutoff valve only get vacumn to close the heater cutoff valve when it is on max air. I will check this out with a guage to make sure that is correct and I could be wrong on that, that is the way I am looking at it. Thanks again Jerry
Old Apr 5, 2012 | 05:03 PM
ocala78pacecar
I put on a new rear hood gasket and it help the amount of heat coming in thru the vents. I am going to work on the vent door this weekend and make sure there is no leaking there. Thanks for the help Jerry
Old Apr 14, 2012 | 01:33 PM
ocala78pacecar
I when thru all the vent doors and they were fine. I charge the A/C with r12 and put a shut off valve in and low and behold it like a different car, I have to run the A/C on low where before it was like I did not have any A/C. The list is getting shorter and the car is looking and driving better. Thanks for all your help Jerry
To 78 interior heat
