Coated Headers
Old Apr 11, 2012 | 09:00 PM
McVette's Avatar
McVette
well now scott money is an object.............lol
can i get some feedback on these....just food for thought...........lol................... ..http://www.summitracing.com/parts/HED-68308/
Old Apr 11, 2012 | 09:28 PM
scottyp99's Avatar
scottyp99
They look like generic headers made to fit more than one kind of car. I have been looking at these:
http://www.summitracing.com/parts/BIG-31106FLT/
They are made by Flowtech, but if you look carefully at the pics, they appear to be identical to these:
http://www.summitracing.com/search/P...E/?Ns=Rank|Asc
I have heard quite a few people who have nothing but good things to say about the Summit headers in the second link, excellent fit, quality, etc. and the Flowtech headers in the first link appear to be the exact same header, but coated, so you should have good luck with it. And the price is so right, it makes me feel like dancin'!!!!!
Keep the shiny side up!
Scott
Old Apr 12, 2012 | 01:31 PM
jcloving's Avatar
jcloving
Here are some shots of mine. Just installed. They are from Josh Powers at Custom Image Corvettes. Jet Hot Sterling coated inside and out. Stock '76 L-48
headers before coating below:
Lots of clearance to the frame, steering box, Z-bar. I used the 576S plugs from ACCEL and so far they are perfect.
Old Apr 12, 2012 | 06:22 PM
McVette's Avatar
McVette
wooooooow looks sweet...not sure that might be in my price range tight now tho...looks expensive...........lol
Old Apr 13, 2012 | 08:59 AM
RIO68's Avatar
RIO68
I don't know about anyone else but the more I look at different listings the more confused I get! Long tube, y connector, short style--wow what is the best? I did a desk top dyno check on my engine and quickly saw that headers make a whale of a difference in HP using them over stock manifolds. It is apparent that money spend to increase performance is wasted if you don't do something about exhaust. I guess the magic question is which ones to use???
Old Apr 13, 2012 | 09:46 AM
cv67's Avatar
cv67
St. Jude Donor '05
hard to go wrong with just about any 1-5/8 tube header. Look for a good thick flange to the head
Those equal length tuned headers=waste of dough and can make getting to things difficult. Youll never notice the small power increase they claim.
Old Apr 13, 2012 | 03:06 PM
paragonspirit's Avatar
paragonspirit
I have been under my car a lot recently and noticed a thick steel plate that does not look 'factory.' I'm not sure I can recommend it to others as an option for addressing cabin temperatures, but I'll take a picture or two over the weekend so you can asses for yourselves.
SS
Old Apr 13, 2012 | 04:07 PM
AdamMeh's Avatar
AdamMeh
Originally Posted by vettehardt
Whatever coating you go with, make sure they are coated inside and out. If they aren't coated inside, what you mechanic is describing will still rust the pipes. A good ceramic coating will work. Jet hot seems to be one of the more popular brands.
Had ours coated inside and out. They look fantastic and as some others have said, you can't believe the temp difference until you experience it for yourself. Another nice thing is the durability of the coating. I dripped some oil on the headers while hot (during our break in run). It stained the ceramic slightly. Just sanded it with 2000 grit wet paper (LIGHTLY) and polished it with some aluminum polish - looked like brand new again. Even melted plastic from a plug wire separator came off with a fingernail.
PM me if you would like the info for the company I used here in Phoenix. Much cheaper than Jet Hot and the results were awesome.
Adam
