Getting new tires.....need so help
Old Apr 9, 2012 | 09:26 PM
justin_heat05's Avatar
justin_heat05
Default Getting new tires.....need so help
I recently purchased some new wheels for my c3.
Fronts are 18x8.5 and rears 18x9.5
I won't be lowering the car any because i have side pipes. It sits at stock height.
What size looks the best without lowering the car? I want the widest size for the rear without rubbing and I also want the tire to fill the fenderwell good.
Most sizes ive seen are 245/45s up front and 285/40s in the rear but all of them have been lowered. I'm afraid i will end up with tires that look too small for my ride.
Would like to see some pics as well.
Help appreciated.
Old Apr 10, 2012 | 10:27 AM
MelWff's Avatar
MelWff
How about 245/50 for the front and 285/45 for the rear?
Old Apr 10, 2012 | 10:31 AM
qwank's Avatar
qwank
255/45R18 and 285/40R18 will give you the stock 27" tire height
Old Apr 10, 2012 | 10:59 AM
Marlin's Avatar
Marlin
Make sure to check out the tire makers specs as some tires are slightly taller/shorter/eider/etc... even in the same "size".
I went with 245/45-17 on my 17x8 wheels. Common size and fits the wheel perfect.
To Getting new tires.....need so help
