Little different LED tail lights
Old Apr 10, 2012 | 05:46 PM
C3Paul's Avatar
C3Paul
Default Little different LED tail lights
I have been looking for an alternative to the stock rear lights to comply with UK light spec and this is what I have come up with.
These are the LED lights: http://www.cbsonline.co.uk/product/1...Indicator_RL35
and few more: http://www.cbsonline.co.uk/category/...lusters,b.html
Unfortunately the lights do not come with white LED’S for reverse light, so I have settled for Amber as my reverse lights. (My reverse lights are Inner middle)
Off Mode:
Tail Lights ON:
Indicator/Hazards:
Brake/Fog light:
Old Apr 10, 2012 | 06:03 PM
qwank's Avatar
qwank
I really like those. good job
Old Apr 10, 2012 | 07:05 PM
vetteguy75's Avatar
vetteguy75
LA Events Coordinator
Old Apr 10, 2012 | 08:05 PM
brando1118's Avatar
brando1118
Those are bad a$$
The best looking that I've seen on our cars so far.
Thanks for sharing.
Old Apr 11, 2012 | 08:12 AM
GT's 78's Avatar
GT's 78
Were those sold in pairs or was the price for just 1
Old Apr 11, 2012 | 08:28 AM
GT's 78's Avatar
GT's 78
Ouch!
Old Apr 11, 2012 | 10:36 AM
C3Paul's Avatar
C3Paul
Edit,
the price is for a set (two lights)
Old Apr 11, 2012 | 02:25 PM
worship79's Avatar
worship79
Interesting! How did you wire them?
Old Apr 11, 2012 | 04:23 PM
C3Paul's Avatar
C3Paul
I did have to modify my harness, but in order to use US-spec. cars in Europe you need to modify the harness anyway. (we have to have Amber turn lights)
Cut off the original light plugs and then individually wired each feed for the rear lights, turn lights and reverse lights.
Cut the brake light feed white wire directly from the brake switch (have to do this as the brake and turn lights share the same feed).
Once the feed from the brake switch is cut (white wire) solder a new line in to the cut white wire and run to the back to power the brake lights.
All cars after 1980 must have rear fog light, so had to run another line to power rear fog light. Inner outer circle.
Also had to add two more ground wires and use LED convertor/resistor to power the turn lights.
I can go in to more details if you are interested
Old Apr 18, 2012 | 12:08 AM
MikeKey's Avatar
MikeKey
Wow, beautiful! And the ideas are flowing...
Old May 9, 2012 | 12:37 PM
Mr.Green's Avatar
Mr.Green
Can you pull the light apart to replace the amber LEDs with white/clear LEDs? I would like to replace my backup lights with these and wire in the brake lights to the outer rings, but I'd prefer the white backup.
Old May 9, 2012 | 08:53 PM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
Or, as an alternative you could just install some high watt halogen backup bulbs. Have them on my DD with 20% rear window tint, and I can see just fine out back at night.
Old May 9, 2012 | 10:26 PM
Mr.Green's Avatar
Mr.Green
Not really what I'm looking for. I want a semi-classic look to my '76, but I like the brightness from the LEDs. The factory lights are pretty dim, but if I can't find a good mod (or make a good mod), I'll stick with what I have.
Also, I would like the outer ring to light up!
Old May 10, 2012 | 04:57 AM
C3Paul's Avatar
C3Paul
The lights are glued, so unless you cut them open you won’t be able to change the LED’S
But,
You can wire your brake lights to the outer rings.
Old May 10, 2012 | 10:23 PM
Mr.Green's Avatar
Mr.Green
I was toying with an idea:
I was going to use a ring LED for the brake light and then find a suitable LED light for the backup, keeping the original light covers. I might have to use the brake/turn covers, cut out the center, and replace it with the clear backup one.
Ring LEDs:
http://www.hidlightsusa.com/product.asp?id=R100-33SMD-W
It will take me some time, but I'll let you know how it goes.
Thoughts?
To Little different LED tail lights
