HELP! Vette won't start!
Old May 19, 2002 | 12:17 PM
madmaxgt's Avatar
madmaxgt
Default HELP! Vette won't start!
I completed detailing my engine bay yesterday and started the vette. Had to jump start her cause I left a door open. Anyways today she will not start. I fact no power what so ever even with jumper cables. I mean nothing! All fuses are intact and good. Whats going on here? The only wiring I took off was the Distributer and Alternator, and Im sure they are both back on correct! Where do I go from here? HELP! :mad
Come On! Somebody has to know why I would have "No Power" zero, zilch, Nada! Batter ground is good, all gauges are stuck in place, Tach is at 1500Rpm stuck! Haelp!
[Modified by madmaxgt, 11:10 AM 5/19/2002]
[Modified by madmaxgt, 11:11 AM 5/19/2002]
Old May 19, 2002 | 12:25 PM
82dukman's Avatar
82dukman
Default Re: HELP! Vette won't start! (madmaxgt)
Did you check the fusilbe links at the starter? You don't have any lights/horn etc? Better check ytour grounds too.
Old May 19, 2002 | 12:28 PM
madmaxgt's Avatar
madmaxgt
Default Re: HELP! Vette won't start! (82dukman)
Where at? I checked starter connections but I have "No Power" Nothing! HELP
Old May 19, 2002 | 12:30 PM
82dukman's Avatar
82dukman
No power to the starter? Check your negative battery cable. make sure itnwasn't corroded and when you jumped it, something happened.
Old May 19, 2002 | 01:17 PM
79MakoL82's Avatar
79MakoL82
When you say "no" power, even you're accesories aren't working with the jumper cables on?
Old May 21, 2002 | 01:24 PM
madmaxgt's Avatar
madmaxgt
Well I figured this out it was the fuselink on the drivers side behind the fuse box! You would think the one at the strter would go first ?
To HELP! Vette won't start!
