So I was having issues with my heat and A/C system not working right and found some bad vacuum lines. So I bought the kit and have been trying to decide if it would be wise to remove the dash to run all the new lines.
I also have to replace a few light bulbs in the gauges and Im going to replace the vacuum hoses for the headlights.
So what has everyone else done? Just work inside the dash or remove it?
Dash Out. I'm doing this right now.
Be ready to find more stuff than you expected. Bubba will make an appearance.
IMHO, taking the dash completely out was not bad at all. it was my first time doing this on a C3, and the peace of mind I am getting by making sure things are done right back there is worth it to me. Be sure to look for burnt plug connectors and frayed wires, and of course, your vacuum lines. Drop the column too.
Good Luck.
Well, pull it all if you want to, but I think you can reach everything except for the headlight switch with just the right dash panel and the trans tunnel console removed. Now, if you need to do other work on the gauge panel and/or the driver's side, pulling all of it might be better.
If you don't pull it all out, you should remove the driver's side seat so that you can improve access to the underside of that dash area.
Have you ever taken the dash out before??? It's a lot of work to get everything back in place and working again correctly. It would be easier to take it out to work on stuff, but each time you take it apart, you take a chance on breaking something, leaving screws out, or "while I am at it" with start and you'll be broke!
There is nothing AC related behind the driver's dash. You should be able to access everything with the passenger's side dash pad out and the center cluster removed.
Define headlight hoses? Under the hood or to the headlight switch? Do you need to replace hoses behind the driver's dash?
Easy Mike is correct. There are no 'HVAC-related' vacuum lines behind the driver's dash. But, there are vacuum lines there, and problems with those vacuum lines can impact other vacuum devices. So, you only need to know that there are no leaks in that vacuum 'stuff' which services headlights (and wiper door, if you have one).
Thanks guys. Its a 79 and has headlight issues also. I bought both vacuum hose kits. The one for Hvac and the headlight one. I also need to replace about half the bulbs in my gauges. So Im going to pull the dash and fix everything properly and the dash has a small crack in it that Im going to address before it becomes a big one. Not sure how Im going to fix yet but I will figure it out when I get that far
Yes, under those circumstances, you should pull both dash pads....at least, pull the driver's dash enough to get good access to the bulbs and headlamp switch.
But, before you 'dig in', do some thinking about "other" areas that you want to address while the dash is open: radio, speakers, insulation, heater/AC work (servos, cables, door seals, etc), ductwork, heater core check/replacement. You don't want to do that job twice in the time span of your ownership.
I replaced the radio/speakers last year and I picked up all new seals for the A/C box. The heater wont be rehooked up since the car will never be driven in cold weather. Been thinking about removing the heater core?
...Yes, under those circumstances, you should pull both dash pads....at least, pull the driver's dash enough to get good access to the bulbs and headlamp switch...
Sorry guys... but it's a 79...
Don't pull the dash pad, pull the speedo tach housing, center gauge bezel and the shift console, and the glove box assembly only. You can access everything you need from there....
This page will show you how to take everything out.. just stop at the part where you pull the pad.
thanks a ton! I was thinking of removing it and fixing a small crack but I think I'll live with it until I have the money to buy a new wire harness and dash pad.
@ Willcox. I was on your website and was wondering if part number HE99E-0114 was the complete headlight vacuum kit. I work and sleep funny hours so when I had a chance to call there was no answer.
Yes, that kit will replace all the hoses on the car for the headlamp system 73-79. Boy.. how you found it I have no idea. I move them over to headlamp and added "Headlamp" to the description.
Willcox
Thanks! Lol ya I had a hard time finding it, but I was sure you had it so I searched for "vacuum" and that was the only result that looked like it worked.
Yes, but can you get to the A/C air valve without pulling the dash.
Are you talking about the actuator behind the heater box toward the driver side? If so, yes you can. when everything is removed you have pretty good access. You'd have to take the box loose from the firewall. (shown on the left side of the picture below)
If you have an issue with the plastic door portion of this then by all means you can reach this part with the pad still installed. (shown by the "Here" below"
Yes, that's the one. Not sure how you would get to the actuator itself to run a new vacuum line without taking the dash out and dissassembling the whole thing. I had the glove box and center gauge cluster/console removed and still couldn't reach it on my '81. Perhaps major dissassembly of the a/c ducting is required.
Yes.. you must remove the front duct assembly and its really not that hard. If the front of duct is off you can get your finger behind the vacuum pod in that picture but it is a real PITA and you'll fight the firewall insulation but it can be done.
I had the same issue on one of my own cars and I did get the hose on. I probably should have taken the bolts lose from the inner box to the firewall, it would have been way faster and easier.
Even if you remove the dash pad it won't make getting that hose on any easier. It's just in one of those places where it is very hard to get at.
