break pedal/bearing?
purchased a 1979 vette that has 37,000 miles last year in the spring.
I replaced all 4 calipers, the master cylinder, bled and had a nice hard
pedal. Replaced a lot more stuff that had rotted or just fell off or was taken off, but back to my issue.
drove the car and was surprised that i had a pedal pulsating, I have been a certified master mechanic for 20+ years so breaks are not a issue, even old vette's . removed the front wheels and checked and didn't like the look of the rotors so i replaced them this year, and still with the pulsating. so i started in the rear.
put the car on jack stands and removed the wheels and threw on 2 lug nuts on the rotors, started the car and had the assembly spinning. What i didn't see was any major run out or wobble...i was walking around the back of the car to look at the other side and saw the hole TA moving, not much but a little... about as much pedal pulsating. I got it U-Joints!
pulled both haft shafts and saw that although they were rusty and ugly too look at, the u-joints were not frozen or damaged. looked at the bearing/hub and spun them by hand. they both seem tight and smooth.
I don't really believe my bearings were going bad, no growl noise... other than the humm from the ring and pinion. and now i dont think my u-joints are bad and it seems my rotors are not warped. why would my TA's move when the wheel is spinning ?
p.s. i will probably replace the rotors, u-joints and maybe a shock absorber's I am in there right ?
