Engine Build - Anyone ever hear of 207 big block heads?
I'm buying a big block Chevrolet engine with the following components, and I have my own (original) heads, but was curious anyway about the statement that these are the HOT 207 heads....??
Anyone ever hear about 207 big block heads and are there any details about their performance ?
The engine is going in my 73 Big Block Vette...
Engine Details:
CHEVY 454 CI, 455 HP 2 BOLT MAIN
Midnight BIG BLOCK CRATE ENGINE
GREAT MID to HOT!! STREET - 207 HEADS !!
Torque range: 492 to 525 ft/lbs of torque
<< This One is A Real Torquer >>
HIGH PERFORMANCE, Dyno Tested With
YOU IN MIND for the street!
THIS ENGINE WAS BUILT FROM ONE OF OUR DYNO PACKAGES
Engine Will Run on unleaded fuel 91+
DOME PISTONS 9.5 + SEAL POWER HYPEREUTECTIC
Cam is BIG 550 + Hydraulic Dual Patterned High performance
2800 + Stall Speed Convertor Required
This One is A Real Thumper
GREAT OLD SCHOOL SOUND
Heavy Duty Roller Timing chain high per
PER Screw In Studs, Guide plates
SSB Roller Rockers, SSB Molly Push Rods
STEEL FORGED RODS, NODULAR CRANK
NEW Dual Plane High Rise Intake Manifold
New Harmonic Balancer, Flex plate
Chrome valve covers or call colors painted
Chrome or Painted Timing chain cover, 5 qt oil pan
Power 4® cam kit Speed Pro 530-550
Power 4® Speed Pro hydraulic lifters
Power 4® spring set, heavy duty (1010 series sets)
Dual plane High rise intake manifold
One-piece stainless steel intake valves 207
One-piece stainless steel exhaust valves 1.7
Premium positive valve seals,polyacrylate
Heavy duty,hp roller timing chain
Controlled internal oil system (a PER exclusive!)
Heavy duty, high volume oil pump Melling
Heavy duty steel collar oil shaft
Heavy duty oil pickup screen
High quality Speed Pro Dome hypereutectic pistons
PER® HP plasma moly rings Speed Pro
Brass freeze plug kit,gallery plugs kit
High quality rear main seal double lip polyacrylate
Fle Pro PermaTorque heavy duty gaskets and gasket set
Clevite 77 Main bearings,Real Tri metal, high quality
Clevite 77 Rod bearings, Real Tri metal, high quality
New rod nuts ARPs installed
Cam bearings, high quality 360 Set
POWER 4® ENGINE MACHINE LABOR includes:
PER 4-angle® valve job
Mill-matching suface heads
Heavy duty thick wall valve guides
Valve guides custom cut for posi-seals
Jet vat block and magnifluxing
Remove and replace all freeze plugs
Remove and replace gallery plugs
Remove and replace cam bearings
Custom centerline boring of block
True 90 degree V8 centerline boring
Power hone to fit pistons and rings
Custom crank Micro polish radius oil holes
Rods pressed off, then heat fitted
A R P Rods Bolts Install
Rods checked for alignment
Street Race balancing
Thanks for any feedback on the 207 heads....
Mike
Engine Details:
Mike
Received 1,877 Likes
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
Not sure...there are 702's and 206's.....
Looking at the parts list I wonder if they are trying to refer to valve size? Normally a 2.06" intake. I see the same thing written beside the intake valve size and then they say 1.7 beside exhaust valves.
Not sure what you're planning for this engine...but it appears to be a stock rebuild with hypereutectic pistons, stock rods, cast crank etc etc. I would really verify mfg names because other than the bearings and ARP rod bolts...all that house brand stuff scares me as being the cheapest of the cheapest.
You might look into VortecPro in Co. Springs. He builds some real nice packages for good prices with good parts and is very picky about machine work quality.
JIM
JIM
Stock type rebuild. Pressed pin pistons. hyper pistons, not square decked, No torque plate hone. NO name internals. 2800 convertor required in a 9.5 to 1 comp engine? I would be very wary of this engine.
http://inlandempire.craigslist.org/pts/2907902161.html
Phoenix engines.....................RUN!!!!!!!!
http://www.ripoffreport.com/director...ix-Engine.aspx
http://phoenixengine.com/Chevy-27.html
