changing rear end oil on an 82
i want to change the rear end oil before i go back to the track friday. i don't think it's ever been changed since it left bowling green in 82. question is do i need the GM posi additive if i use synthetic gear oil. and what's the thinnest gear lube weight i can use. i'm looking for the lowest drag.
Just went through this.
Regular oil, non synthetic is recommended, 75-90.
The idea it to allow your limited slip work around corners.
Synthetic allows it to slip in a straight line.
Some even put in a partial bottle of GM's limited slip additive and if it still makes noise in a corner they add more.
Royal Purple does not require any additive nor does Mobil 1 LS.
But are they too slippery is the question.
I stayed with regular oil and GM's additive.
Ralph
Ralph
Hooey on the comments about not using synthetic gear oil in the rear end. GM didn't recommend it because it wasn't readily available in 1982. Later on, GM didn't 'revise' oil specs for the C3's because they were over 10 years old.
There is NO documentation that synthetic oil would be problematic for the rear gears; just like there is NO documentation that it would be OK for [C3] rear gears. Basically, there is NO documentation either way.
But, other CF members have used synthetic oil in the differential for years without any problem. So, the choice is up to the owner.
There is no question that gears and wearing parts live a much longer life when lubricated with [good] synthetic oils/grease, instead of the organic stuff. Either will work fine, IMO. But, you still need the Posi-trac additive if you choose synthetic.
Received 4,565 Likes
2016 C2 of Year
2015 C3 of Year Finalist
I've been using 80/90 Gear weight oil and 1 4 oz bottle of GM posi lube in the rear ends of my 61, 65 and 68 for many years (41 years in my 65). They are all original rear ends that have never been out of the cars. It works
good info guys!!!i saw the royal purple and almost bought it. but i had already bought the GM additive. so i went with regular 80-90 weight i think. i could only get @ a pint, maybe less out of it. it needed a oil change bad. i only bought 2 quarts and it took almost all of it.
I love synthetic oils. Ran Mobil 1 since 1974 or so.
But in the rear end the old stuff seems to be just fine.
Like capevettes said 41 years and still going strong.
And there is still the valid question about synthetic being too slippery for these rear ends.
May not of made the perfect choice but it's still a good one.
Ralph
Ralph
2016 C2 of Year
a little off topic but...
Would going to a Quick Lube place be able to do this (change the diff oil with the proper sfuff)? I take my regular car there and they are pretty thorough. I also don't have a 'sucker' to get the old lube out and would like to change it out.
Thanks, Jim
Thanks, Jim
Thanks, Jim
Thanks, Jim
