Iron tight ceramic sealer
Old Apr 17, 2012 | 04:01 PM
georgeculolias's Avatar
georgeculolias
Default Iron tight ceramic sealer
I bought some rebuilt heads off ebay a couple of years ago and when I just finished the car coolant was pouring out the exhaust. After tearing the engine down again I had the heads pressure tested and they found the new guides were leaking coolant. He suggested using this Iron tight ceramic sealer but said he didn't do it. I'm in Brea California or orange county.
Has anyone ever had this done and knows where it can be done and how much?
Old Apr 17, 2012 | 05:26 PM
noonie's Avatar
noonie
Not familiar with that stuff but this Blue Devil does work in most cases, but the instructions must be followed carefully.
Most auto parts have it for 40+ bucks. Yellow and blue bottle.
Used on the infamous Caddy engines.
http://www.usasealants.com/products/...asket-sealant/
Old Apr 17, 2012 | 06:50 PM
georgeculolias
I'd like the shop to do it so I can have it pressure tested while off the car. I'd hate to have new valve guides replaced.
Old Apr 17, 2012 | 09:21 PM
ezobens's Avatar
ezobens
I'm currently in a similar situation.
Just installed my brand new Profiler heads and had to use the Cometic .027 MLS head gaskets to get the quench down.
Cleaned everything and installed the gaskets (dry) and heads as directed but then noticed a wet spot in 2 places at the bottom of the one head a few days after filling the coolant (have not started the motor).
Previous shop that did the block decking left the surface way too coarse for the MLS gaskets to seal properly. Story of my life..
Damn! And these are $100 a pop gaskets too!
So my current engine guy suggested to try Moroso's 'Weather Seal' before I tear the whole motor apart again. He's seen it do some pretty amazing stuff so I figure I'm only out a couple of days and the $14 for the sealer. While it's not my first repair method of choice, I REALLY don't want to tear the whole top end off again either if I don't absolutely have to.
Stuff arrives tomorrow-
I'll keep everyone posted on if/how it works.
Keep your fingers crossed!
Elm
Old Apr 18, 2012 | 11:26 AM
georgeculolias
Elm
Does anyone know where or if this can be done on a set of heads already off the car?
Old Apr 18, 2012 | 12:04 PM
noonie's Avatar
noonie
Engine has to be running.
All these better sealants contain Sodium Silicate (liquid glass) and it hardens and seals when it comes in contact with air in a cooling system.
For a rough finish, you may want to try the old spray on copper sealer when assembling.
Old Apr 18, 2012 | 12:09 PM
billla's Avatar
billla
St. Jude Donor '14
Are they MLS or rubber-coated MLS?
I'd be a lot more worried that the deck isn't FLAT than the Ra is too high...
Old Apr 18, 2012 | 11:40 PM
ezobens's Avatar
ezobens
They are Cometic Viton coated MLS gaskets. RA is off the charts.
Deck is flat, the shop that originally did the work were butchers.
They must have cut the deck at the fastest rate their equipment could cut.
I still have the original Fel Pro 1014s I took off and you can feel the cut marks pressed into the material. The Fel Pros sealed just fine- The deck surface is just to damn rough for MLS.
Unfortunately, when I showed the original gaskets to my current builder, he couldn't believe the texture and said there was no way in hell my MLS gaskets would seal on that surface.
So the 'Weather Seal' option is out and I just ordered another set of 1014s.
That blows my quench from about .045 to .057 but I don't have a choice unless I yank the block and have it cut.
Since I have to pull the motor again next winter to install my TKO and A/C, I'll have to live with the crappy quench for this year and then I'll have the block decked correctly while I have it out next year.
Man I'm getting good at taking stuff apart/out and putting it back together... I just HATE scraping off old gaskets and RTV sealer!
Elm
To Iron tight ceramic sealer
