Weeping carb- No joke
Old Apr 18, 2012 | 07:33 AM
silver79's Avatar
silver79
Default Weeping carb- No joke
After A 10-20 drive I hear a weeping sound that is coming from the carb, any suggestions.
Old Apr 18, 2012 | 07:57 AM
bashcraft's Avatar
bashcraft
WTH does a "weeping sound" sound like?
Old Apr 18, 2012 | 08:18 AM
capevettes's Avatar
capevettes
CF Community Team
Active Streak: 90 Days
2016 C2 of Year
2015 C3 of Year Finalist
In reference to a carb, weeping usually means leaking. Audible sounds like whistling usually are indicative of a vacuum leak often at the base of the carb where it sits on the intake (gasket issue).
Old Apr 18, 2012 | 08:48 AM
7T1vette's Avatar
7T1vette
Gasket problem at carb base and/or gasket problem with carb. Manifold vacuum is finding a way 'out' of the carb assembly, somehow. Wait till it happens again, then remove air cleaner and tighten the main carb hold-down bolts a bit. Don't exceed specified torque for those bolts, but check to see if the sound changes when you tighten them.
If that has a significant effect, you can then try to determine exactly where the vacuum leak is by spraying little puffs of brake cleaner at speicific spots on those gaskets. When aimed at the vacuum leak, the engine should increase in rpm's a bit.
Once you've determined the exact point of leakage, you can decide how to permanently fix it. And, NO, duct tape is NOT the answer!
Old Apr 18, 2012 | 02:49 PM
superdave269's Avatar
superdave269
Spray around the carb. If you cover the leak you will be able to hear it by the different sound the engine makes. I have had good luck finding vacuum leaks this way.
Old Apr 19, 2012 | 08:02 AM
silver79's Avatar
silver79
Thanks guys never thought about a vacuum leak....I will check.
Now how about the bad and overly rich fuel smell. Is it a jet thing or a mixture thing? I have a speed Demond no air pollution control
Old Apr 19, 2012 | 08:17 AM
gcusmano74's Avatar
gcusmano74
No, no. The weeping sound is actually coming from your wallet............
Old Apr 19, 2012 | 01:56 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
mine is outright sobbing a step up would be weeping
Old Apr 19, 2012 | 02:38 PM
midyearvette's Avatar
midyearvette
all kiding aside, im' surprised no one has mentioned "Fuel percolation"
this usually happens after you shutoff a hot mill and the fuel in the carb bowls starts to boil and yes you can hear it
also will cause a rich smelling condition
normal stuff with a carbed engine.....this could be your problem...jmo....good luck....
Old Apr 19, 2012 | 07:52 PM
scottyp99's Avatar
scottyp99
If your carb hold down nuts are already pretty tight, you can loosen them a little and see if the sound gets louder or changes somehow. Also, if a vacuum leak is making noise, a less messy way of tracking it down is to take a length of hose and stick one end in your ear and listen around with the other end. You'll be surprised how easy it is to track down vacuum leaks, exhaust leaks, etc. using a hose as a stethoscope.
The fuel percolation theory may make sense, as it only happens after you drive it for awhile. I've never actually experienced it myself, so I can't really say all that much about it, but on the other hand, I've never seen a vacuum leak that came and went, either. Doesn't mean it can't happen, though, I guess. Yeah, I know, big help, right? LOL! Sorry I can't be of more help, man.
Keep the shiny side up!
Scott
Old Apr 20, 2012 | 07:51 AM
silver79's Avatar
silver79
you guys are killing me
Old Apr 20, 2012 | 07:52 AM
silver79's Avatar
silver79
No sure about the perculation theory but I will check after today after work.
To Weeping carb- No joke
