How heavy is a 77 Hood?
Old Apr 18, 2012 | 08:09 AM
xkeots's Avatar
xkeots
Default How heavy is a 77 Hood?
Hi,
I want to strip and repaint my hood. I also want to take it off but I need to know if I can lift it myself or need help?
Jack
77 L82
Old Apr 18, 2012 | 08:24 AM
hugie82's Avatar
hugie82
It's light. Less than 20lbs.
Old Apr 18, 2012 | 08:28 AM
hugie82's Avatar
hugie82
Place some towels around the edges and bottom
Old Apr 18, 2012 | 11:05 AM
MelWff's Avatar
MelWff
I would get a friend to assist, cannt imagine that it's less than 20lbs.
Old Apr 18, 2012 | 11:30 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Bulky, but you can lift it. Four hands are better than two.
Old Apr 18, 2012 | 11:34 AM
75vetteman's Avatar
75vetteman
From: some hole in the ground town- camp verde:) arizona
well since i have the hood off mine, i weighed it just now- 42 lbs
i've tried doing it myself and it's hard to support one side while you remove the bolts from the other. anyways, i didn't succeed by myself. best to have an assistant
Old Apr 18, 2012 | 12:23 PM
paragonspirit's Avatar
paragonspirit
I needed assistants to get the hood off, but now that the hinges/bolts are disconnected I can tilt it and lift it (very carefully) and move it off the car. Works out since I haven't a garage.
I'd believe the 42 lbs as an accurate number, the sound deadening might add or subtract ~3lbs but otherwise you should be very close to that number. Awkward to move alone though, and as I said above, removal requires more people.
Old Apr 18, 2012 | 01:01 PM
hugie82's Avatar
hugie82
I use to carry my 74 hood with one hand. But 42 lbs is probably correct. I was a lot younger than ...LOL
Old Apr 19, 2012 | 07:56 AM
71scgc's Avatar
71scgc
Not heavy.
Get a helper for removal, though...
Old Apr 19, 2012 | 10:47 PM
vettehardt's Avatar
vettehardt
I was able to remove the hood on my 76 by myself fairly easily. I did however need help getting the bolts lined back up when putting it back on. Just couldn't quite do that myself.
Old Apr 20, 2012 | 02:28 AM
Pelayo114's Avatar
Pelayo114
The hood on my 77 is fairly light but just a bit bulky so I had someone help me remove it and put it back on, just so that I wouldn't damage it in any way. I wouldn't try doing it alone just so that you won't accidentally bump it or scratch it anywhere.
Old Apr 21, 2012 | 04:09 PM
xkeots's Avatar
xkeots
My son is 12. Since I know the weight I can have him help me take it off and I can paint it off the car.
When I am done, I can have him bolt it while I hold it.
Thanks Much
Jack
77 L-82
To How heavy is a 77 Hood?
