Bonehead move on Thermostat
Old Apr 12, 2012 | 06:50 PM
Mgrad92's Avatar
Mgrad92
Default Bonehead move on Thermostat
Well, I really screwed it up this time. I needed to replace my thermostat, so I was loosening one of the thermostat housing bolts. Well, it was rusted in there pretty good and I snapped the head right off.
Since I was already screwed, to I decided to take the other one off. It looked like a stud with a nut on it, so I tried to remove it and *SNAP* it broke too. (Obviously these bolts had not been removed in forever.)
The good news is that the thermostat housing came off but now I'm left with this:
How the hell do I get what remains of those bolts out of the intake manifold?
Old Apr 12, 2012 | 07:07 PM
69Vett's Avatar
69Vett
Corvette of the Year Winner 2017
2016 C3 of Year Finalist
wow, atleast your consistant !
your gonna have to drill and tap. duct tap the T-stat hole, to keep out the chips.
you might have had bolts to long, and they bottomed out, and are frozen on the threads.
is your manifold aluminum ?
grind the bolts off flat and square, use a center punch and dimple a center spot.
start with a small bit, and drill your pilot hole straight and square in the center of the bolt.
if you go off center, you will just hog out the aluminum around the bolt.
slowly working up to the size hole and tap you need.
Don't drill thru the bottom of the bolt holes.
All of this is much harder on the car, but do able, go buy some new drill bits.
Straight and square pilot hole... right thru the bolt center,
Don't drill thru the blind hole in the manifold. (Not to Deep)
Old Apr 12, 2012 | 07:08 PM
JimT's Avatar
JimT
Go to sears and buy the nut style bolt removers. The nut slides down over the broken bolt, and when rotating it in the counter-clockwise direction it will snag the bolt and back it out. First though, soak the bolts with pb blaster, or any good penetrating oil..
good luck!
Old Apr 12, 2012 | 07:18 PM
Ben Lurkin's Avatar
Ben Lurkin
St. Jude Donor '09
Do none of the above. Doing this by hand will will likely end up ruining your manifold.
Get two. Nuts and place them over the existing broken stubs. Weld them to the studs. Allow them to cool. Apply a good rust penetrant and let it soak for a day. The heat from welding and the lube should allow them to break free.
Old Apr 12, 2012 | 07:56 PM
Mgrad92's Avatar
Mgrad92
Three opinions. Hmmmm. I think I'm going to soak the bolts in penetrating oil tonight and try the bolt removal tool tomorrow. (the only welder I have is a spot welder)
Old Apr 12, 2012 | 07:59 PM
70Speedray's Avatar
70Speedray
Default Kroil and Heat are your friends...
Just my opinion, but after trying other penetrating oils, including PB Blaster, I have found that Kroil does the best job. The aerosol version of Kroil is AeroKroil. Google on "Kano Labs", buy direct. Expensive, but worth every penny. Let it sit overnight, or even two days with reapplication.
As expressed above, heat is your friend. Welding the nuts on is the best bet. Without access to a welder, the nut style extractors may work with heat applied to the manifold. Even with welding on the nuts, gently heating the manifold with a torch right before attempting to back out the studs will expand the female hole, and loosen the grip on the studs. You will have to drain the AF before you apply heat.
Old Apr 12, 2012 | 08:06 PM
billla's Avatar
billla
St. Jude Donor '14
Drilling this out in the car is going to just make a mess and screw up the manifold for sure.
If you don't have a welder, then just pull the intak and take it to a shop...or take the opportunity for an intake upgrade
Old Apr 12, 2012 | 08:19 PM
Marlin's Avatar
Marlin
Does not look there is enough to install 2 bolts, good idea if there was though.
I would try a extractor. Drill the center of the bolt and try an extractor. If that does not work then drill and tap.
Old Apr 12, 2012 | 08:21 PM
jnb5101's Avatar
jnb5101
you're going to have to drill those puppies out. as mentioned, cover the coolant hole. then grind the top of the bolts flat. then use a dremmel like bit to make a center dimple. if you aren't exactly in the center, regrind the top flat (it helps to visualize the entire bolt so you can see the center)and try again. then use a small bit (1/8") and make your first cut the entire length of the bolt. i like the home depot brand bits (rigid) at slow speed, firm pressure and lots of oil. then increase to the size bit needed to retap the hole(i think it's a 3/8 so you need 21/64"). then just retap. don't rush!!!! the manifold metal is softer than the bolt steel, and if you drift off-center you're screwed. i've drilled out more of these rusted bolts than i care to think about, and the only time i have problems is when i rush the job. you'll be surprised how quickly a sharp bit will cut thru the bolt.
Old Apr 12, 2012 | 08:47 PM
Tim H's Avatar
Tim H
Really?
Just break out the welder and weld it up!
Not everybody has a welder or can weld, so now what?
All that would do is break the bolt off at the bottom of the first nut anyways.
The PB blaster is the only hope, otherwise its tap and die.
I would put a set of vise grips on them and work them back and forth and that might work also after the pb blaster.
Old Apr 12, 2012 | 08:54 PM
7T1vette's Avatar
7T1vette
Looks like an aluminum manifold and steel bolts. When dissimilar metals are 'engaged' some galvanic action is created between them and corrosion is the next step. They will almost weld together, as a result...very difficult to get them to separate well.
When you get the bolt stubs out (and you will, I'm sure), make sure you use some anti-sieze on the bolts/studs you reinstall. Also, you will need to reduce the applied torque, as the anti-sieze will act as a lubricant. Use the torque spec. for lubricated threads (usually about 60% of 'dry' install torque value).
Good luck.
Old Apr 12, 2012 | 09:24 PM
Mgrad92's Avatar
Mgrad92
I drained the Antifreeze and the bolts are soaking in PB blaster this evening. Tomorrow I'll heat the manifold around the bolts with my MAP gas torch and try the nut type bolt removers. I figure if they don't work, I can always drill a hole in the bolts and use the extractors that you insert into the hole. If that fails, I'll use the grind, drill and tap method.
This should be interesting.
Thanks for all the info.
Old Apr 12, 2012 | 11:22 PM
7t9l82's Avatar
7t9l82
here's an off the wall one. get a stud pliers heat up the stud and melt candle wax on it. it actually worked on one for me another time not so much. if you take it off I'd get a different manifold.
Old Apr 12, 2012 | 11:52 PM
daanbc's Avatar
daanbc
St. Jude Donor '12
Please be careful of the gas in carb. It's not the gas, it's the fumes that ignite. If it was me, I would just remove the carb. and distrib. And take the manifold off. Then you can have all the access you need to remove those bolts, then you can paint the whole manifold if need be. Or just go ahead and by a new one. But be carful of the fumes and a flame.!
Old Apr 13, 2012 | 02:45 AM
Clubby99's Avatar
Clubby99
I'd just buy a new manifold. They don't cost that much.
If you do drill and tap, take the manifold off the engine first? A more work but may save you major heartache if you mess up.
Old Apr 13, 2012 | 05:00 AM
gingerbreadman1977's Avatar
gingerbreadman1977
So far im with timH, its amazing how strong a nice set of vice grips can grab a thread. Use the penetrating oil of your choice and give it a go next day.
If that fails i would have a go at drilling but like most have said with the manifold off. Drill to deep with that manifold on the car and some metal shavings fall through it could mean GOODNIGHT for that motor.
I would think about a new manifold as well.
Old Apr 13, 2012 | 06:24 AM
7T1vette's Avatar
7T1vette
Do what you can with it on the engine. When you need to get more aggressive, you can remove it to limit risk to the engine. If it gets the best of you, then you can take it to a machine shop for repair, or just buy another manifold, if that will be less expense.
If you are patient, I think you can fix it on the car.
To Bonehead move on Thermostat
Old Apr 13, 2012 | 06:33 AM
bryanpl123's Avatar
bryanpl123
I would cover the hole well, plugged with a cloth and covered with tape. Apply PB blaster a few time over a 24hr period, try out some vice grips and then if that doesn't work get an easy out bit. You have to drill a shallow pilot hole then use the easy out bit.
Old Apr 13, 2012 | 08:25 AM
imariver's Avatar
imariver
Old Apr 13, 2012 | 08:50 AM
qwank's Avatar
qwank
Penetrating oil, heat, then vice grips. Should come out with no problem.
