aftermarket gauge cluster
Looks like they pieced it all together with what they wanted
http://www.vetteweb.com/tech/vemp_11...r/viewall.html
Just took the back of the OEM gauge set off, and mounted the Autometers through the holes left by the OEM's. The 2-1/8" gauges fit perfectly.
I must point out though that only the consoles with the round holes (pre-78? with flat bottoms?) work. The earlier gauge facia will work though.
hth
This is an easy swap with the 2 /1/16th or 52mm gauges. The car in the photo you provided is an early C3 gauge cluster and these gauges will just pop right in. There are subtle differences in the years but 68-76 clusters will be a drop in. I used Autometer Elite gauges and it took 5 minutes to mount all the gauges with the cluster out of the car on a table. The work comes in planning on how you are going to wire them up. You have to source an ignition power wire, ground and if you purchase gauges with an incandescent back light, a source for that as well. My gauges are backlit with an LED light so I didn't need a power source to dimmable light power. Wouldn't matter anyway because you can't dim LED's. After you've planned for power, you need to decide if you want to or can use your existing sending units. The Autometer gauges come with their own sending units so I used them and ran all new wires to the cluster.
For ignition 'ON' power, I used the pink wire from my old fuel gauge and ran it to a relay that powers a small bus bar. I bundled my power wires from my guages, put a inline fuse in and ran it to the bus bar. You can also "daisy chain' your power and ground wires. I just decided to bundle mine. You don't need to use a relay and bus bar, I just wanted a easily accessible source for ignition on power for future stuff. All you need is to find an ignition 'ON' source, put a fuse in line and hook your gauge power wires to it. Here's a pic of the bus bar and relay.
I created a ground bus bar and mounted it on the back of my gauge cluster. Again, you don't have to do it this way. I just wanted an place where I could get a good ground that is in the center of the dash. All you need to do is source a good ground from behind your dash and run the ground wire to your bundle or 'daisy chained' ground from your gauges. Here's a few pics of my ground bus bar and bundled ground wires from my gauges.
For the sending units you may be able to use the existing ones, depending on what gauges you decide to purchase. I didn't want to mess with it and I liked the sending units and connectors that Autometer supplied so I ran them all through the car. It was just three sensors. I used a 6.3 mm blade connector to make it easier to take the gauge cluster out.
There are lots of ways to go with gauges and the folks on this forum have some killer setups. Some make their own gauge cluster bezels and others have done some really amazing things with LED lights. It really is your canvas. Good luck.
car is 79 N/A 350, head, cam carb, intake,exhaust modified, 3 speed with 4.11 so I run rather high RPM on the road cycling between 3rd and N due to noise... (I don't drag race but I hard launch and orange-line it thru gears)
engine oil temp?
trans oil temp?
vacuum?
I already have an A/F ratio in the glove box
what else useful is there?
