Solid Motor Mounts
Old Apr 21, 2012 | 03:57 PM
brian76's Avatar
brian76
Default Solid Motor Mounts
Does anybody use them? I have them in mine and it shakes the car but I do run a Comp XE274S cam. I was thinking of switching to a poly mount- anybody run those, and how much of a differance does it make over standard rubber mounts? I can live with the solids, I just know that the women love it, because they tell me that feels just like a Harley. Thanks
Old Apr 21, 2012 | 04:32 PM
Belgian1979vette's Avatar
Belgian1979vette
IMO bad on the street. Some oil pumps in the engine seem to have problems with solids.
Stay away from poly.
Old Apr 21, 2012 | 04:56 PM
AdamMeh's Avatar
AdamMeh
?? I'm confused.
Old Apr 21, 2012 | 04:58 PM
69small block's Avatar
69small block
what problem have you had with poly mounts
Old Apr 21, 2012 | 05:59 PM
bashcraft's Avatar
bashcraft
Old Apr 21, 2012 | 06:23 PM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
I've got solids in mine, I'm sure there is some vibration...but I don't notice it. I ran stock interlocking style for years with no issue either. Take your pic.
JIM
Old Apr 21, 2012 | 07:26 PM
vette427-sbc's Avatar
vette427-sbc
Solids here too... It also stiffens up the front a noticeable amount. I havent had any issues with excessive vibration or the oil pump (?!)
Old Apr 22, 2012 | 01:45 AM
Grumpy 427's Avatar
Grumpy 427
I Have solid mounts on my 80. I have not noticed any issues.
Old Apr 22, 2012 | 03:05 AM
bmans vette's Avatar
bmans vette
St. Jude Donor '12-'13, '15- '16-'17-'18-'19, '21
I have seen other posts where people use solids for the front mounts but a Rubber mount under the trans to get rid of the stiffness. They claim a poly mount under the trans is too stiff.
What have you got under your trans?
My setup is still a year away but I have solids for the front and rubber for the trans.
Bman
Old Apr 22, 2012 | 07:13 AM
Belgian1979vette
Ok, let's talk about this a little.
Some here say it stiffens up the front. I believe that. However the forces have to go somewhere and where do they go to ? Yes, into the engine. Now, you may think the engine block is an incredibly strong piece of steel right ? Wrong, hence the reason why they use torque plates to hone them. If you use solid mounts, the engine will deform, although minute, causing less sealing of the rings.
The standard oil pumps today have smaller mounts. Take a look at the website of the manufacturers. They advice against using a standard pump when using solid mounts...not without reason.
As for poly : I've seen it crack and break. It doesn't help you with the engine movement. If you plan on a poly mount, you can just as well go to a solid one.
Just my opinion on things. Your call.
Old Apr 22, 2012 | 10:32 AM
7t9l82's Avatar
7t9l82
start that one, once upon a time!
Old Apr 22, 2012 | 10:54 AM
hugie82's Avatar
hugie82
My friend had solid in his nova. The vibes at certain rpm would vibrate the windows so bad they would fall out of the tracks if not closed.
Old Apr 22, 2012 | 11:05 AM
bashcraft's Avatar
bashcraft
Sounds like your friend needs to have his rotating assembly balanced.
Old Apr 22, 2012 | 11:10 AM
drwet's Avatar
drwet
I have poly mounts in my '79. I put them in thinking they would be stronger after I broke a rubber mount. They definietely transmit more vibration to the cockpit. I later read that they are no stronger than rubber, so I added a cable to keep the engine in place. Next time I have the engine out, I'm going back to rubber. If the solid mounts transmit more vibration than the poly, I wouldn't use them, but that's a personal taste thing. Lots of guys like to feel every vibe and hear all the engine noise they can as part of the Corvette experience. I'm too old for that.
Old Apr 22, 2012 | 11:56 AM
bmans vette
Back in the day (late 60's) we would beef up our engines only to break the left (driver's side) motor mount. You knew it when the fan started hitting the shroud.
More torque than the factory mount could handle.
So we replaced the mount with a new stock one but then added a homemade "torque strap". Mine was a big-azz turnbuckle from the frame to a extra head bolt bolted into the head from the side.
Instead of breaking the mount the left front tire lifted off the ground on hard launches.
Seems like solid mounts serve the same function.
Like I said - add a rubber mount under the trans.
imo
Bman
Old Apr 22, 2012 | 01:52 PM
hugie82's Avatar
hugie82
Harmonics is a bitch with 4:88 on the highway
Old Apr 22, 2012 | 03:53 PM
billla's Avatar
billla
St. Jude Donor '14
Solid mounts make the engine to some extent a "stressed member" of the chassis. It does improve chassis stiffness...but on the street with all the flex of daily driving I would personally pass.
I've run polys on street engines with no issues at all, but that's just me.
Just one' guy's take.
To Solid Motor Mounts
Old Apr 23, 2012 | 09:09 AM
bashcraft's Avatar
bashcraft
For the first 5 years after I bought my '69 it had 4.56 gears. Never had a problem with harmonics.
Old Apr 23, 2012 | 11:04 AM
Ironcross's Avatar
Ironcross
Race cars use motor plates and the transmission is suspended........to use solid OE style mounts in a passenger car {and that's what a Vette is} will probably stress transmission mounts and at the least break tail-shafts..... other than that it might sound good while bench racing and have some possible bragging rights.....Other than these points, GM has used cables through the front mounts on the L-78 1967 Camaro engines......but nothing solid anywhere
Old Apr 23, 2012 | 12:36 PM
lars's Avatar
lars
Originally Posted by 427Hotrod
I've got solids in mine, I'm sure there is some vibration...but I don't notice it. JIM
I've been running solid mounts for years with no issues. I don't notice any vibration in my big-cammed engines that's any worse than a stock mount. No broken parts. No problem with oil pump. No ring seal problem. No broken tranny tailshaft housing. No harmonics. None of the wive's tales about solid mounts. Only difference is that I'm not replacing ripped-out rubber mounts every 3 months...
Lars
