MasterCylinder Replacement
Old Apr 22, 2012 | 09:33 AM
1972vettman's Avatar
1972vettman
Default MasterCylinder Replacement
Just replaced old calipers (new VB&P O-ring models) and all the brake lines on my 72
I now need to get a new master cylinder, was thinking of going with the Wilwood part number 260-8556P (power brakes) but have a couple of questions:
1. Will it operate with the old style calipers?
2. Will the brake lines install without modification?
This web site http://www.cssbinc.com/1967-76non-po...inder-new.aspx shows a replacement M/C that I have never seen. Has any one used or heard anything good or bad about them? Appears the added bleeders are to make bench bleeding easier?
I know there is major work in front of me as far as bench bleeding new M/C and bleeding entire system. I have read as many posts concerning this as my eyes will allow I already wear pretty thick glasses
I've got a question or two about what I've read concerning gravity bleeding. Is it really as simple as attaching drain hose to all bleeders funneling to a fluid catcher (jar), opening all the bleeders up, making sure M/C is full of fluid at all times and waiting for the fluid to flow?
Once this is done, each of the calipers needs to bled individually starting with the farthest away, correct?
Old Apr 26, 2012 | 05:40 AM
1972vettman
Can't belielve with all the knowledge on this forum there was not one response!
Old Apr 26, 2012 | 07:43 AM
VTHokie77Vette's Avatar
VTHokie77Vette
I just put the Wilwood master cylinder in my '77 this weekend. I went with the all black one and its a very nice piece. I bench bled it, then bled the calipers starting from the furthest away. I haven't driven it too much, but so far it works great. Does it work better than the stock version... not that I noticed. The reason I got it was because I liked the look of it in my engine compartment a lot more. I'm sure it would work fine with the stock calipers, I'm running the Wilwood D8's on mine though. Also, I did not have to modify any of the brake lines. The front fitting threaded right on the the master cylinder, the back fitting required using one of the supplied adapters.
To MasterCylinder Replacement
