parasitic battery drain
Old Apr 26, 2012 | 10:57 AM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Originally Posted by wombvette
But the electrical part of the switch is down on the bottom of the column, and other than the rod from the tumbler itself, has nothing to do with the key part. It could be that the electrical switch is not adjusted correctly or that the rack gear in the column is broken, or that the bearing housing is broken or loose, but if he can start the car normally, thats not likely.
All true. It just seems suspect, and I've seen a few cars here and there where wear on the key switch caused odd problems with the electrical portion. The fact that the OP says it doesn't drain with the key in the "ACC" position but does with the key off seems really suspect.
