Caliper Rebuild
Old Apr 22, 2012 | 05:35 PM
LongIsland C3's Avatar
LongIsland C3
Default Caliper Rebuild
Anyone know which is the best and most complete caliper rebuilding kit? There's a ton of them out there, and as usual, I'm starting to overthink it. Thank's.
Old Apr 22, 2012 | 06:10 PM
Marlin's Avatar
Marlin
This is the one I bought.
http://fixvetteparts.com/cgi-bin/online/storepro.php
Does all 4 calipers and has new bolts and bleeders.
Old Apr 22, 2012 | 06:28 PM
rponfick's Avatar
rponfick
I would not mess with rebuilding them. Have tried, but never with much success. If you still have original calipers, they are likely pitted and difficult to smooth, and get a good seal on the new pistons. If they have already been sleeved, maybe possible to use rebuild kit because the stainless steel sleeves do not corrode as easily. Rebuilt calipers are pretty cheap these days. I think even Auto Zone and the other parts stores carry pretty good units, some with a lifetime warranty.
Ralph.
Old Apr 22, 2012 | 06:29 PM
Marlin's Avatar
Marlin
Hard to find a C3 Corvette caliper that has not already been sleaved. Mine were already SS so I just rebuilt them.
But I would remove a piston and make sure yours has the SS already. If so rebuild, if not buy a reman set.
Old Apr 22, 2012 | 06:46 PM
longbros's Avatar
longbros
I use these guys with great results. www.muskegonbrake.com
Old Apr 22, 2012 | 07:10 PM
Alan 71's Avatar
Alan 71
Hi LIC,
One thing you may want to check in to is the sealing method of your rebuild kit.
The originals had 'lip' seals, but there are now 'O-Ring"' seals too.
Using 0-ring seals requires new pistons, but you may want to consider them since people report they seal very well.
Good Luck!
Regards,
Alan
Old Apr 22, 2012 | 08:53 PM
mds3013's Avatar
mds3013
If you chose to rebuild yours or want to see what to look for, ck. here. mike...
http://forums.corvetteforum.com/c3-g...-calipers.html
To Caliper Rebuild
