Transmission swap
Old Apr 22, 2012 | 07:01 PM
Dblancha's Avatar
Dblancha
8th Gear
Default Transmission swap
I have a 79' L82 with 350 cu in motor and automatic 3 speed transmission.
I would like to install a 4 or 5 speed automatic transmission with overdrive.
Does anyone know if there is one that fits current torque converter and with out having to change drive shaft length?
Old Apr 22, 2012 | 08:07 PM
oldalaskaman's Avatar
oldalaskaman
its well documented, do a search
Old Apr 22, 2012 | 09:47 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
start your research at
www.700r4.com
the drive shaft shortening is not a big deal
Old Apr 22, 2012 | 10:49 PM
drwet's Avatar
drwet
I did the 700R-4 swap. Its nice because you can use a lot of factory parts if you get the right tailshaft housing, since the factory put them in these cars in '82. Oldalaskaman is right. Been discussed a gazillion times on this forum. Do a search.
Old Apr 23, 2012 | 04:41 AM
themetalman03886's Avatar
themetalman03886
2004r, have to swap for a lockup torque converter but the drive shaft stays the same. I had one before I went to a T56, worked real good and was a very easy and cheap swap
Old Apr 23, 2012 | 10:12 AM
larrywalk's Avatar
larrywalk
Veteran: Marine Corps
200-4r
Old Apr 23, 2012 | 11:05 AM
qwank's Avatar
qwank
I would go with the 700R4 unless you're running some crazy low gears like 4.11s or 4.56s
Old Apr 23, 2012 | 04:00 PM
iokepakai's Avatar
iokepakai
Match your rear gears with the trans for best results......
From Bowtie OD:
The first gear ratio of a TH-700R4 is 3.06 to 1. This is 21% lower than the first gear ratio in a TH-350 ( 2.52 to 1). First gear ratio of the Th-700R4 is 23% lower than a TH-400 ( 2.48 to 1 ). Maybe the following example will help you make sense of this. These examples don't take into account any torque multiplication may be occurring through the torque converter, they are just to illustrate the numerical gear multiplication. The subject vehicle is a 1960s classic car with a 3.08:1 rear end. With a TH-350 you multiply the 2.52 first gear times the rear end ratio of 3.08 and you come up with a torque multiplication number of 7.76 to 1. If you are accelerating and your motor was developing 100 lbs. of torque at that moment, your rear tires have 776 lbs. of torque applied to it. (7.76 x 100 lbs = 776 lbs). With a TH-400 you multiply the 2.48 first gear ratio times the rear end ratio of 3.08 and you come up with a torque multiplication number of 7.64. If your motor were developing 100 lbs. of torque, your rear tire could have 764 lbs. of torque applied to it at that moment. (7.64 x 100 lbs = 764 lbs) With a TH-700R4 you multiply the 3.06 first gear ratio times the rear end ratio of 3.08 and you come up with a torque multiplication number of 9.42. If your motor were developing 100 lbs. of torque, your rear tire could have 942 lbs. of torque applied to it at that moment. (9.42 X 100 lbs = 9.42 lbs).
Conclusion
This car would feel 166 pounds more torque with the Th-700R4 transmission then a TH-350 in first gear and 178 pounds more torque than the TH-400 in first gear. To have the same torque multiplication with the TH-350 or TH-400 we would have to run a 3.73:1 rear end ratio. Now with the TH-350 first gear of 2.52 x 3.73 = 9.40 x 100 lbs of torque produced by the motor = 940 lbs felt at the tire. Also the TH-400 first gear of 2.48 x 3.73 = 9.25 x 100 lbs of torque produced by the motor = 925 lbs felt at the tire. If you have any Hot Rod blood running through your veins, this has to sound like fun running around town on Friday night. If you were looking to lower cruise RPM we just went the wrong way with this example. Running a 3.73 to 1 rear end gear ratio sure won't help gas mileage or lower your cruise RPM down the highway. With a 26" diameter tire and 3.73:1 rear end with the transmission in 1 to 1 third gear like the TH-350 or TH-400 in high gear, your engine would be turning approximately 2889 RPM at 60 MPH. This is not a pretty picture!
Solution
Install a TH-700R4 with these existing 3.08 rear end gears. This car will launch like a TH-350 or TH-400 with 3.73:1 rear end ears, so you can now have your stop light fun. When the Th-700R4 goes into fourth gear, your final drive ratio will be 2.16:1. (3.08:1 rear end ratio x .70:1 4th gear ratio in the Th-700R4 = 2.16:1 overall final drive ratio) With a 26" diameter tire, a 3.08:1 rear end ratio and the Th-700R4 in .70:1 fourth gear, your engine would be turning only 1670 RPM at 60 MPH. This is a pretty picture!
Automatic Transmission Gear Ratios
1st 2nd 3rd 4th Reverse
GM
Powerglide 1.76 1.00 1.76
TH350 2.52 1.52 1.00 1.93
TH400 2.48 1.48 1.00 2.00
200r4 2.74 1.57 1.00 0.67 2.07
700r4 3.06 1.62 1.00 0.70 2.29
4L60E 3.06 1.62 1.00 0.70 2.29
4L80E 2.48 1.48 1.00 0.75 2.08
What's your rear end ratio?
Old Apr 23, 2012 | 04:06 PM
SH-60B's Avatar
SH-60B
Originally Posted by larrywalk
200-4r
Old Apr 23, 2012 | 09:06 PM
Dblancha's Avatar
Dblancha
8th Gear
From Bowtie OD:
Conclusion
Solution
GM
3.55 rear gears. thanks for great information
Old Apr 24, 2012 | 04:59 PM
drwet's Avatar
drwet
Funny you should say that...
I have 3.55 gears in my '79 with the 700R4. First gear is a little too deep. From a pure gear ratio standpoint, you might be better off with the 200-4R. I can't say how it fits, although others on this forum swear by it. I just like the 700R-4 because it is a nice clean installation. If you get the factory parts its a bolt in and I like stuff that looks factory.
Great info from iokepakai. I learned a few things.
Old Apr 24, 2012 | 07:53 PM
iokepakai's Avatar
iokepakai
With that 3.55 ratio a 200r4 would be a good choice.Check out Bowtie Overdrives,they have a tubular crossmember for the C3 that bolts up.I think you can use your existing driveshaft with no mods.Did the trans swap thing last year.After much research decided to go Richmond 6 spd due to my 3.08 rear gears and I liked the idea of a manual over an automatic.The gear spacing is just about perfect no large drops of rpm's.Fuel mileage has improved to 20 mpg's on the highway.
Just about the best change with the Vette so far.....
Old Apr 24, 2012 | 09:19 PM
drwet's Avatar
drwet
Where did you get your Richmond? Does it bolt up to a stock bellhousing? Shifter handle line up OK? I'm thinking about swapping out the 700R-4 for a stick. Sportscars need a stick!
Old Apr 25, 2012 | 06:34 PM
SH-60B's Avatar
SH-60B
The factory crossmember works fine. Just unbolt the TH350 mount bracket and the TH200-4R bolts right on.
To Transmission swap
