1971 manual window crank
Old Apr 23, 2012 | 12:09 PM
HunterPayne's Avatar
HunterPayne
Default 1971 manual window crank
I am trying to determine the cause of a sloppy window crank. The window rollers and bushings look ok down in the tracks, but when I bring the window up or down the crank seems sloppy. I mean that I am turning the crank but the window does not move at the same time. It is hard to explain, so I am hoping that someone has had this experience.
Old Apr 23, 2012 | 12:13 PM
MelWff's Avatar
MelWff
the crank always has some slop in it, 1/2 inch either way, do you have more than that?
Old Apr 23, 2012 | 12:40 PM
HunterPayne
Yes, it seems more than that. To the point where I try to help the window up and down with my hand on the top of the glass. The slop seems to be where the handle is. The passenger side seems more like you describe.
Old Apr 23, 2012 | 01:05 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
You may need a regulator after all this time. Driver's side would - naturally- wear out sooner than the passenger's side.
Old Apr 23, 2012 | 02:25 PM
Alan 71's Avatar
Alan 71
Hi hp,
It sounds to me like perhaps your winder **** might be worn.
The ****, and the shaft it connects to, both have teeth cut into them that mesh when the **** is pushed on to the shaft. If they're worn, the **** handle slips as you wind it up or down.
Both the **** and the shaft are available.
Maybe?
Regards,
Alan
Old Apr 24, 2012 | 08:17 AM
HunterPayne
Thank you very much. I was trying to determine what to look for before I tear it apart.
Old Apr 24, 2012 | 07:08 PM
spdrcr29's Avatar
spdrcr29
Its also possible that the bushing is worn out. Just a thought...
Corvette Central as well as other vendors I am sure offers these servicable parts.
Hope this helps.
http://www.parts123.com/parts123/yb....Z5Z5Z50000050G
Old Apr 24, 2012 | 09:13 PM
Ghunt's Avatar
Ghunt
I just went through this, maybe not the same as yours.
I replaced my cranks to only look better but after a while they were very sloppy and wouldn't work. I thought that the regulator or something else was broken. turned out the after market cranks
splines werent as long as the originals and the depth of the hole where the shaft goes in wasn't as deep and not allowing the spring "C" clip to grab the grove in the shaft.
I put the OEM's back on and all good.
Can't trust this ChiCom junk.
George
Old Apr 25, 2012 | 08:52 AM
jnb5101's Avatar
jnb5101
ghunt has it right-it's the after market cranks.
To 1971 manual window crank
