Blown header gasket
Old Apr 27, 2012 | 03:31 AM
richiev88's Avatar
richiev88
Default Blown header gasket
My less than 300 miles , header gaskets have blown out one port....and it would be the left side!!!
I've driven it a couple of times since, some one mentioned possibility of burning the exhast valve??? anyone had this issue?
What sort of distance would you need to travel to cause damage ?
When i stared it up from cold today, it was like it backfired a few time whilst idling out of the side pipe ( side with blown gasket) it was a full on bang!!
I guess it was unburned fuel in the side pipe ?
Ideas
Cheers
Old Apr 27, 2012 | 07:27 AM
gkull's Avatar
gkull
Fel Pro blue steel exhaust gaskets never blow out. I even reuse them multiple times. But I also use ARP studs and put on the nuts so they never need retightening
Old Apr 27, 2012 | 08:16 AM
69 Chevy's Avatar
69 Chevy
I had my right side Mr Gasket #150-A header sidepipe blow a 1/2" chunk out of the top of the #4 gasket last week on its maiden voyage for this driving season. At idle I could see fire spitting out the void. I would guess it happened less than 5 miles from home on the return leg. Ho hum, it's happened before; I'm sure it'll happen again.
Turns out the header bolts loosened up even though I used red Loctite on the threads. And I'm guessing the restrictive muffler inserts I had in didn't help things by causing backpressure thus forcing out that section of the gasket that wasn't clamped tight enough.
I cannot say how many miles it would take to warp an exhaust valve from a slight exhaust leak like mine. I think the chances are slight...more of a noisy nuisance than an engine destroying problem. I would tend to think there would not be enough cold air reversion to harm that valve.
Old Apr 27, 2012 | 11:36 AM
1yy07's Avatar
1yy07
Default headder gasket
stage 8 locking fasteners. get the one inch ones NOT 3/4.1-800-843-7836. www.stage8.com
Old Apr 27, 2012 | 01:31 PM
hugie82's Avatar
hugie82
Use the stock OEM manifold gaskets. Never blew one in 30 years
Old Apr 27, 2012 | 03:31 PM
richiev88's Avatar
richiev88
Yes, I too had restrictive reverse flow inserts on initial runs, may have contributed to the gasket blowing out.
Also initial timing was a bit retarded so primary pipes got quite hot when it was first fired up!
Yes, I work as a mechanic and have never seen burnt valves from this, but hey, there is a wealth of experence here, interesting to ask of others experiences, specific to these cars.
Have tried to buy the copper gaskets here (NZ) but no one seems to have stock, have bought felpro #1411 gaskets, $55 here, see how we go.
Thanks Richie
To Blown header gasket
