Temperature Senders
Old May 20, 2002 | 08:51 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Default Temperature Senders
I am installing the temperature senders on my new heads and am wondering why there are two senders on my car. One on the passenger head is for what? The one on the drivers side head is for what? Passenger side has two connections. The one on the driverside has one connection. What gives?
Old May 20, 2002 | 09:27 PM
Sigforty's Avatar
Sigforty
Cruise-In IX Veteran
Default Re: Temperature Senders (Eddie 96)
The passenger side sender is part of the TCS system on your car. Mine also has the same set up.
Mark B.
Old May 22, 2002 | 09:49 PM
Eddie 70's Avatar
Eddie 70
Default Re: Temperature Senders (Sigforty)
What is the TCS system and what does it do?
Old May 23, 2002 | 10:11 AM
Sigforty's Avatar
Sigforty
["TCS"; Transmission Controlled Spark. Installed on all engines starting in 1970, It switched in or out the vacuum to the distributor depending on temperature and transmission gear.]
I took this from chevelles.com I hope it helps give an idea of what the system does.
Mark B.
Old May 23, 2002 | 10:17 AM
Gator81's Avatar
Gator81
On my '81, the p.side head sender is for the auxiliary electric cooling fan. The one in the d.side head is for the temp gauge.
:seeya
Old May 25, 2002 | 08:50 AM
Eddie 70's Avatar
Eddie 70
Default Re: Temperature Senders (Gator81)
Hey guys thanks for the info. There is a plug that is hanging down on the side of the engine bay and I am guessing that this is where this goes. I may try connecting it back up and see how bad it hurts my performance when I get it all back together. Thanks for the the info. :yesnod:
Old May 25, 2002 | 09:38 AM
stumpbuster's Avatar
stumpbuster
i have the same setup. however, i would think that the rear sender (p) side would give a true reading as to the temp of the engine. just a thought.......the further back on the block, the hotter the engine temp gets..........
Old May 26, 2002 | 09:40 AM
KenSny's Avatar
KenSny
Default Re: Temperature Senders (stumpbuster)
Huh - you're kidding, right? Sorry, but I find that reasoning quite funny......
Old May 26, 2002 | 09:59 AM
tictocdok's Avatar
tictocdok
Default Re: Temperature Senders (KenSny)
KenSny; the water from th water pump gets pushed into the block, and then it flows to the heads>intake manifold> out the upper radiator hose to the rad.
some of the water "short circuits" and does not go all the way to the rear of the motor before it exits out the upper hose, so the rear of the motor doesn't cool as well
Old May 26, 2002 | 12:26 PM
KenSny's Avatar
KenSny
Default Re: Temperature Senders (tictocdok)
I seriously doubt if there is any measurable difference between the sender mounted on the driver's side head (closer to the front) than the passenger side (closer to the rear). At any rate it would not be enough "worry about" for fan control or gauge readings......
Different story if you are talking about mounting a sensor on the intake manifold vs heads tho....
To Temperature Senders
