ac Blower motor location
Old Apr 28, 2012 | 09:03 PM
kf4cln's Avatar
kf4cln
Default ac Blower motor location
Hello all, been a while no problems just driving, now I have a question. The ac compressors kicks on and I can feel cold air trying to come thru vents, but no forced air blowing. So I figure its the blower motor, pull out the old handy dandy Chiltons book and it shows a location under fender. I cant find any thing that looks big enough to be a blower and cage assembly. Any help will be appreciated... location location.
Thanks everybody !
1980 corvette non L82
Robert
Old Apr 28, 2012 | 10:09 PM
speedreed8's Avatar
speedreed8
its under the passenger side fender mounted to the ac box
http://www.keenparts.com/pages/Catal...ice=5&year=ALL
Old Apr 29, 2012 | 11:35 PM
1986coupe's Avatar
1986coupe
does the blower work with the heater?
Does it work at some speeds but not others? If so check the resistor.
Old Apr 30, 2012 | 07:51 PM
kf4cln's Avatar
kf4cln
Checked the blower motor and it blows fine. It's just not blowing out the vents like it has been. Anything else I can try ?
Robert
Old Apr 30, 2012 | 09:15 PM
SIXFOOTER's Avatar
SIXFOOTER
Your duct doors are probably not operating. the vac switch in the center console controls vac to them. The duct doors are in the AC ducts, operated either bt a cable or a vac solenoid. Frequently the switch leaks, vac line broken at the firewall. Also count on there being a gap between the main AC box and the dash duct assembly, very poor fiting from the factory, Prepare to take the dash apart, this WILL suck
Old Apr 30, 2012 | 10:11 PM
maxmachz's Avatar
maxmachz
If it only blows out the heater / lower vents, this is the default position when there is no vacuum to the selector switch.
My bet is vac line seperated just behind the distributor, look closely there and you'll see it coming through the firewall up high right in plain view. Just to the right of the distributor.
Old Jan 21, 2023 | 12:29 AM
Mike Noble's Avatar
Mike Noble
5th Gear
Default Just saying thanks
Same problem on my C7 16. Went straight to the plug and it fixed it. Just wanted to drop a thank you.
Old May 13, 2023 | 08:29 PM
smajicek's Avatar
smajicek
I just ordered this plug 19368864, does it come with wires that need to be spliced to the wires after cutting off the old plug?
To ac Blower motor location
