Most guages doesn't work.
Old Apr 29, 2012 | 03:19 PM
superdave269's Avatar
superdave269
Default Most guages doesn't work.
We started a C3 that has been garaged for a few yrs and the oil pressure, battery, and clock do not work. Temp & fuel did..The oil pressure guage not working really surprised me. I have never had any issues with them before. No tapping so it's getting oil pressure. Any tips you guys can share?
Old Apr 29, 2012 | 03:27 PM
KenSny's Avatar
KenSny
Sounds like a blown fuse.
Unless, of course critters have been chewing on the wires.
Old Apr 29, 2012 | 03:48 PM
superdave269
I did check fuses they all seamed good. I did not look for any chewed up wires yet. Any other trouble shooting tips? Any ideas were I should go for a new clock? If I change the guts will it affect the hole original thing?
Old Apr 29, 2012 | 03:59 PM
Mike Ward's Avatar
Mike Ward
Oil pressure gauge on a '73 is mechanical only.
Old Apr 29, 2012 | 04:24 PM
superdave269
I assumed it was mechanical that's why I was surprised it doesn't work.
Old Apr 29, 2012 | 07:10 PM
7T1vette's Avatar
7T1vette
Either the pressure tubing or the inlet of the gauge is plugged up with solidified oil/gunk which won't pass the pressure. You can 'unplug' either, but you have to get the gauge/tubing to where you can work on them.
The early "battery" gauge is an ammeter. When all is 'good', the gauge should read "0". With engine OFF, turn on the headlights. If the ammeter needle drops below the "0" mark [indicating a discharge], the meter is working as expected. If no movement at all, it could a gauge or wiring problem.
The clock will have to be removed for repair. There are rebuild kits for the original clock mechanism; there are also quartz [electric] kits to swap out the clock 'guts' to make it like a modern (analog) clock.
Old Apr 29, 2012 | 07:33 PM
superdave269
Thanks. I'll try to unclog the tube. The gas meter was clogged up from sitting too. The ampmeter should move if there is power on the wire so I should be able to tell if it's bad or not. It's always something!
Old Apr 30, 2012 | 03:18 PM
superdave269
I spent some time on this today. The oil tube is not clogged up. Also the battery guage does have power on the wires as my test light did light up. I believe it's time for new guages.
To Most guages doesn't work.
