Checking EGR & PCV valves
Old May 1, 2012 | 03:12 PM
Iron_dog's Avatar
Iron_dog
Default Checking EGR & PCV valves
Guys, I would like to check if EGR and PCV valves are working OK.
PCV valve is correctly connected to the manifold vacuum, while EGR is not connected any more. Any suggestions on how to check them? Thanks
Old May 1, 2012 | 03:44 PM
MelWff's Avatar
MelWff
PCV test is typically if it rattles when you shake it, it's not stuck. With the engine running, if you pull the valve out of the valve cover you will feel suction on the exposed end.
Old May 1, 2012 | 03:52 PM
Iron_dog's Avatar
Iron_dog
Thanks, tested and it rattles, also I feel suction! This one is good...
Old May 2, 2012 | 03:39 AM
Iron_dog's Avatar
Iron_dog
Any suggestion for EGR valve?
To Checking EGR & PCV valves
