Turn signal question
Old May 3, 2012 | 10:18 PM
72bowtieguy's Avatar
72bowtieguy
Default Turn signal question
Did a search for this but not sure I found the exact answer, my passenger side turn signals don't blink. They do light up, and the drivers side signals work. Also they do blink with the emergency flasher switch on, just not with the turn signal switch.
Old May 3, 2012 | 11:24 PM
my 76 ray's Avatar
my 76 ray
Check your front side marker bulb. Usually when turn signals don't blink on one side a bulb is burned out.
Old May 4, 2012 | 12:05 AM
72bowtieguy
To clarify all bulbs work, the passenger side ones simply don't blink on and off. They do when I depress the emergency flasher switch on the steering column though, just not when I pull down on the turn signal stalk.
Old May 4, 2012 | 07:54 AM
...Roger...'s Avatar
...Roger...
First,the turn signals and emergency flashers use 2 different flashers,you could swap the 2 flashers to see if one of the flashers will flash easier.
Second, I'm guessing if you look really close while with the emergency flashers are on you'll see one of the bulbs is slightly dimmer than the others,that will be your problem bulb,possibly poorly grounded.
Old May 4, 2012 | 07:57 AM
Alan 71's Avatar
Alan 71
Hi Roger,
VERY good to see you posting on the Forum!
Regards,
Alan
To Turn signal question
