AC for Dummies Help needed
Old May 7, 2012 | 01:38 PM
spinout's Avatar
spinout
Cruising
Default AC for Dummies Help needed
OK I read the manual but its Greek to me, I'm not a AC guru. I have an 82 and I believe the compressor is needing replacement, is this something I can swap out? I don't use the AC but its a problem. My question then is, in simple steps how do I change this out? I'm not sure about the pressure and freon in the system. I'm afraid if I take this in they are going to want to rebuild the whole system and charge me big money for a system I don't use, I don't want to remove it, thanks guys!
Old May 7, 2012 | 01:45 PM
Garys 68's Avatar
Garys 68
Just get new belts to skip the compressor pulley.
Old May 7, 2012 | 02:38 PM
spinout's Avatar
spinout
Cruising
DOH! Good option - if I wanted to replace the compressor is it safe to disconnect and reconnect the lines without special tools?
Old May 7, 2012 | 03:02 PM
Garys 68's Avatar
Garys 68
You're supposed to have the freon recovered (environmental reasons). But there's no reason to remove the compressor if you dont use it.
Leave the old one there until you decide to fix the whole system, new compressor, drier, valve, blow out evaporator/condenser/lines.
Old May 7, 2012 | 03:15 PM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
You want to be sure the system is not under charge (has refrigerant). To do this, just remove one of the caps where the gauges are screw on to and slightly depress the schrader valve to see if any refrigerant escapes. If not, you can unbolt the compressor hose attachment and the compressor retaining bolts.
If the system is charged, legally you can not dispense refrigerant into the open air and should see a qualified a/c specialist to recapture the gas before opening the system. However, you want to be sure the compressor is bad before replacing it as they are not cheap. If I were you, I'd get a couple of repair estimates to see what the system needs if you plan on getting it working prior to spending any $. Most garages don't charge for this service.
Old May 7, 2012 | 04:16 PM
spinout's Avatar
spinout
Cruising
Perfect! You guys are the best!
Old May 7, 2012 | 11:36 PM
lvmyvt76's Avatar
lvmyvt76
Don't take the compressor off and leave the system open to the atmosphere, if you ever want to have the ac working again, it will cost a lot more to fix that problem than what you have now.
Old May 8, 2012 | 02:35 PM
commander_47's Avatar
commander_47
Redoing your A/C system is not that complicated. You will need a couple of inexpensive tools, and a vacuum provided you have an air compressor.
I got a rebuilt vette compressor, drier, orifice tube, and all the instructions from here:
http://www.autoacsystems.com/_faqs/d...ompressor.html
Place is called CoolZone AC, and you can talk to Angel.
I got a rebuilt compressor and all the parts I needed for less than 150.00. Also, all this was setup for R134.
You can get the Schrader valves and gaskets from auto zone.
I got the big hose from an online "Parts Warehouse" for 65.00.
If your system is left open, or whenever you replace the compressor, your biggest enemy is dust and dirt. You can "vacuum" your entire system by getting a little 20 dollar pump at harbor freight. You hook it up to your comprressor and your completed and sealed A/C system. Then let it run for about 30 minutes.
Get the R134 recharge kit from autozone....and enjoy cold air.
Old May 8, 2012 | 02:56 PM
spinout's Avatar
spinout
Cruising
This sounds "doable" if I talk to Angel and with your explanation, I have a compressor and most tools needed for most jobs but I may have another trip to HF in my future. Thanks for the simplified explanation, my head hurt after reading the manual!
Old May 9, 2012 | 12:56 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
No disrespect, but it is against the law to vent R12 into the atmosphere anywhere you go. In many states, it is against the law to tamper with automotive AC systems unless you are a certified automotive HVAC technician.
My advice would be to check your local laws before you do anything further.
Any automative AC shop can keep your stock system running and charged.
Old May 9, 2012 | 05:27 PM
EmNash's Avatar
EmNash
9 times out of ten low refridgerant pressure is the culprit. There is a low pressure saftey switch that prevents the compresser from engaging. This switch can be bypassed briefly to see if the comp clutch engages. If it does then you need to track down a leak and recharge, may be best done by a AC shop.
Old May 9, 2012 | 05:40 PM
spinout's Avatar
spinout
Cruising
OK guys, after having a chance to research the procedures a little closer, and understanding the process better with your help, I think I can go to a qualified person to look at this and understand if whats being done is correct or unnecessary and if I'm getting what is right. I have no intention of releasing the freon into the atmosphere (but I wonder what happens to all the scrap cars?). Anyway, although I'm OK on most of the mechanicals this requires some special tools and I don't plan on using my car for a guinea pig with myself on this one, thanks to all for your input.
To AC for Dummies Help needed
