Won't start
Old May 8, 2012 | 04:19 PM
Billem's Avatar
Billem
Default Won't start
Had a problem starting a while back but hadn't reoccurred until today. Turned the key this morning and nothing happened. Figured I hadn't pressed the clutch ('74 4spd) in far enuf. Tried it again and started right up. Went to the gas station, filled the tank, hit the starter and nothing. Tried 4-5 more times, nothing. Called AAA and an hour later got towed home. Had them set it in the driveway. Tried again. This time there was a feeling like a spring or something like that broke when I went to "start". Now the ignition switch freewheels thru the run position thru the start position and back to the off position. It still allows the shift lever in/out of reverse when you go from off to run but there is no "start" position. It sounds like I have at least 2 problems and I have no idea where to start on either one. The more detailed info that can be provided will be greatly appreciated. Have a great day, Bill
Old May 8, 2012 | 07:10 PM
jnb5101's Avatar
jnb5101
there's a plastic rack that connects a 'push rod' that extends from the key mechanism to the ignition switch to select off, run, start, etc.
it sounds like the old plastic has given up the ghost. check jim shea's papers for repair info.
Old May 8, 2012 | 07:56 PM
my 76 ray's Avatar
my 76 ray
They may be related. The key may have been starting to fail.
Old May 8, 2012 | 09:26 PM
palmbeachvette76's Avatar
palmbeachvette76
Sounds like the starter switch located under the dash on the steering column that I replaced yesterday on mine. Same thing, one time it starts the next the power comes on but in the "start" position nothing but air. A few more tries it might start.
The contact wears down inside the switch creating a greater distance and sometimes the rod can reach sometimes it can't. It's not a fun job but not terribly difficult and the part in my case was $16 at Advance Auto. Took 30 minutes to install just very limited space to work with.
To Won't start
