Need to build up my '81 -HELP
Any one have any idea what kind of HP gain I might get out of a setup I listed above?
[Modified by KENTUCKY81, 5:44 PM 5/21/2002]
Here's what I did with my '81. The crate engine is a 355ci, 330hp, 390lb/ft, unit from Summit, and I've been very happy with it, but I don't think they sell them any more. Too bad.
http://www.rogerscorvette.com/free/morris.htm
If I were doing it again today, I would seriously consider a ZZ4 crate motor from GM, and do everything else the same way I did. I would also look for a 406 crate motor, or consider having a local machine shop build a 406 for me. I went with a 355 because I was worried about emissions, but this motor makes less emissions than the stocker did!! :crazy: So I would definitely, seriously, look at a 406. I think the ultimate emissions-friendly crate motor for a '81 Vette would be a 400 built with a new GM 4.125" bore block and all the ZZ4-spec parts... that would probably cost you around $4k, maybe $4500. Just for comparison, I got my 355 from Summit for only $2100! :D But that's probably why they don't sell them anymore - they weren't making any money... doh! :eek:
[Modified by Gator81, 8:30 AM 5/23/2002]
BTW, Do you have any pics of your car KENTUCKY81? I also have a beige 81.
There are things like removing the carbon filter from your air cleaner, and running a K&N air filter, and going to true duals with no cats that you will need to do no matter what motor you go with. All of the motors we are talking about need these things to breath.
Now I am perfectly aware that a crate motor is going to make more power than this, and that a crate motor comes with a warranty, but lets take a look at horsepower for the dollar. If I had the extra money I would be running a ZZ4, but I don't, and am real happy with my current motor. I cruise only, no racing, just respectable street power, and it works out great for that without breaking the bank.
That's what I think, and what I do. :) It's your decision on yours though. :cheers:
-Justin
It all depends on how much hard cash you want to throw at it. If you can afford to put a crate engine in, then go for it (personally I'd go for the most power you can get. The trouble with hp is that you get used to it & then want more :D ).
If the cost of a crate motor is beyond your means (it is for me!) then the L81 can be woken up & perform a lot better than stock. And, of course it all depends on what you want to use the car for: cruising with the odd bit of fun or an all out fire breathing monster to blow the socks off of any unwary challenger!
I haven't got access to a dyno so I can't quote any figures, but what I've done in stages is this:
High output HEI coil & Moroso leads - noticed much better low end performance, felt cleaner/crisper, but the originals could have been past the sell by date?
True dual 2 1/2" exhausts - BIG improvement.
Monza mufflers - seemed to improve it, but if not then the noise was worth it!.
Performer manifold, Moroso lifter valley oil baffle, Crane Compucam 210/216 .440"/.454" (? from memory), Comp cams 1.52:1 roller tipped rockers (not sure if HP increased by them, but it sure sounds impressive down the pub ;) ) - I'm still breaking the cam in, but at low rpm it has been transformed. It feels much, much more responsive & I'm looking forward to the end of the break in period :D
K&N air filter - This alone causes much strife on both sides of the "pond". Some people love them, some hate them. What I do know for fact is that every Bike that I've fitted a K&N to has needed the jetting changed to make it run richer in some part of the rev range (this is a right royal PITA with a bank of 4 flat slide smoothbores, so if I could have avoided re-jetting I would have done). So, more fuel needed usually means more power coming out. If it doesn't, then not having to clean them frequently, or change them, makes them worth the expense (be honest, how many people change/clean air filters when they should?).
After all this the next logical step is to put some decent flowing heads on & increase the CR. I should have done this to get the full effect of the cam, but have run into a bit of a problem with my bank manager :lol:
After that, a set of headers will be required to get the most out of it at high rpm.
Depending on what you do, if you end up with vast quantities of ponies under your foot, then won't the tranny, driveline, etc, need some money spending on them to cope with the extra power?
One question of my own: Over here it's quite common for people to go to a Breakers (salvage yard) & pull the engine out of a wrecked faster car to drop into theirs (very popular ricer trick). Is it possible to get an LT1 out of a late C4 (for example) & squeeze it under the hood? Surely that would be a cheap(?) way of getting a modern engine along with all the peripherals, rather than spending a lot more on a crate engine? OK, it's risky (not much of a warranty) but we took the same risk when we bought our C3's. If the donor car will still run, then at least you could hear the engine. Just a thought :)
Good luck in whatever you decide,
Paul
