Rough Starter? Maybe?
Old May 9, 2012 | 09:18 PM
jawagner777's Avatar
jawagner777
Default Rough Starter? Maybe?
Hey all My 78 vette is experiencing some bizarre behavior. Wheather cold or hot it seems like the starter struggles to turn the motor over. I first thought the battery was going bad, but, it is a new battery. Threw the battery tender on it and it had a full charge. Still same problem. Took the battery back to the store to have it tested. Tested perfect!! ok so now I am stuck. Could it be the starter? I have the OBX headers and sidepipes but the headder is a good 3 to 4 inches from the starter. It never had this problem but actually started when I installed the stereo system in the car. Just a 12' sub in a custom box i built and a 1000 watt 5 channel amp but only draws 100amps when you pound on it. Could this be a ground problem?
Thanks Guys
Ill post some pics of the stereo for all to see too. It turned out great!!
Old May 10, 2012 | 11:05 AM
69 Chevy's Avatar
69 Chevy
Originally Posted by jawagner777
Just a 12' sub in a custom box i built...
Probably looks like a 12 foot long coffin, huh?
Old May 10, 2012 | 11:21 AM
qwank's Avatar
qwank
check all your cable connections and make sure nothing is corroded or loose.
Old May 10, 2012 | 03:57 PM
LB66383's Avatar
LB66383
Check your battery ground cable connection at the engine. Make sure it is connected to the block at or near the starter.
Old May 10, 2012 | 07:06 PM
Ironcross's Avatar
Ironcross
Its probably the ground from the battery attached to the frame or rear with a short little cable {12-15 inches}.... Often neglected as its almost hidden and over the years becomes corroded....allowing the engine to seek a ground to crank. several sources can be used such as brake lines and transmission cables and lines....its much easier to check this source rather than removing perfectly good batteries and starters and then going to war with a parts counterman claiming they sold you defective heat soak parts.......
{heat soak?} ...no such animal.......
Old May 10, 2012 | 09:30 PM
jawagner777
Ok i cleaned off all the grounds from the battery to the frame, the engine ground that is next to the starter and the starter ground as well. seems to be a bit better actually but not perfect. Once the starter gets turning it seems fine but it takes a second to start to spin but definately better..... Is it possible it could be the selanoid? that would be an easy fix. I am planning on replacing the alternator cable, power cables, and grounds with 4 gauge high current wire anyway. 35 year old wires could use some replacing anyhow....
Old May 10, 2012 | 10:59 PM
GOLF72's Avatar
GOLF72
My Camaro does the same thing and it was the ground wire.
Old May 11, 2012 | 09:37 AM
stingr4y's Avatar
stingr4y
Check your battery ground cable connection at the engine. Make sure it is connected to the block at or near the starter.This is a thick cable that runs from the frame to the engine. It can easily go bad with the engine shaking.
Also check the connection within the battery clamps.
Mine went bad there, and looked perfectly good from the outside. Easy fix though.
Old May 11, 2012 | 12:27 PM
my 76 ray's Avatar
my 76 ray
After you have cleaned/replaced all the cables if it still cranks a bit slow, it may be the starter. Every time I have replaced a starter, I have noticed that the new one cranks faster than the old one did before it failed.
Old May 11, 2012 | 03:09 PM
redman76's Avatar
redman76
St. Jude Donor '09
Check your timinh too. Misadjusted timing can cause the engine to be hard to turn over.
Old May 11, 2012 | 08:53 PM
jawagner777
Ok all the lines are cleaned up.... same problem. Im thinking starter due to overheating from the headders. Does this sound plausable?
The car is timed dead on and cant see how that would effect how it turns over ( or doesnt turn over for that matter) but if it can be ill check it too....
Old May 11, 2012 | 09:01 PM
Peterbuilt's Avatar
Peterbuilt
Default This could be your problem
See post #5
http://forums.corvetteforum.com/c3-t...no-starts.html
Old May 12, 2012 | 09:11 AM
stingr4y's Avatar
stingr4y
My long hot cable got "nicked" inside the transmission tunnel once, causing a similar problem.
It was not easy to see.
If you have a starter / alternator guy in town, he should be able to give you a good starter test. Some of the parts suppliers also do it, but there's no telling what advice you'll get.
Good luck
Old May 13, 2012 | 07:55 PM
my 76 ray's Avatar
my 76 ray
Since you first noticed the problem when you installed the stereo it may be related. Can you disconnect the power to the stereo easily? Disconnect it as close to where you tapped into the power as possible.
Old May 22, 2012 | 09:12 PM
jawagner777
Low and behold it was the starter. She was good and heat soaked and was drawing a ton of amperage. My buddy had high torque starter from his bb that would fit and she starts alot better with the faster crank. It was a great exercise finding all of the ground points in the car and cleaning up all the wiring.
Thanks all for the input.....
Old May 22, 2012 | 09:54 PM
oldalaskaman's Avatar
oldalaskaman
could install AC Delco part #U939 and give your starter a full 12 volts, gets your engine to start quicker, quicker starts, less wear and tear on the starter, they last longer.
To Rough Starter? Maybe?
