Front noise... bearings?
Remove the wheel, remove the calliper and tie it up so it's not hanging by the hose , remove the calliper bracket from the spindle if necessary, if the rotor has been off the hub before mark the location by marking a stud and the position of the rotor on the hub . If the rotor is not loose on the hub just leave it on the hub. Pull the cap off the outside of the hub and you will be looking at a big nut with a cotter pin through it , remove the cotter pin and the nut and the hub will pull straight off .
The outside bearing will fall out but you will have to push the inner one out with a big punch and a hammer . The seal in back is holding it in the hub. Once it is apart you can wash the bearings and the bearing races in the hub to inspect them . You will probably ruin the back seal taking it apart but they are cheap and available at any parts house .
The bearings and the races have a # on them and they will be available at any parts house also .
Bill
Bill
