Head stud sealant
Old May 16, 2012 | 11:54 PM
Dr L-88's Avatar
Dr L-88
2025 Corvette of the Year Winner- Modified
2024 C2 of the Year Winner - Modified
2022 Corvette of the Year Finalist -- Modified
2021 C2 of the Year Winner - Modified
2021 C1 of the Year Winner - Modified
2020 Corvette of the Year (stock)
C2 of Year Winner (stock) 2019
2017 C1 of the Year Finalist
Default Head stud sealant
What is the best way to seal head studs in a cast iron block, when using aluminum heads? Will Teflon tape work adequately?
Also, has anyone had a problem getting an air gap style intake to seal on GM Vortec aluminum heads?
Thanks,
Rex
Old May 17, 2012 | 12:45 AM
gkull's Avatar
gkull
Permatex has something that I have used for years.
http://www.permatex.com/products/Aut...ad_Sealant.htm
Old May 17, 2012 | 12:55 AM
Ben Lurkin's Avatar
Ben Lurkin
St. Jude Donor '09
Permatex #2.
Old May 17, 2012 | 01:35 AM
HamadUP's Avatar
HamadUP
St. Jude Donor '08
I tried quite a few sealants, the best one (and the one I always use now) is the Permatex #2 non hardening sealant.
Old May 17, 2012 | 06:41 AM
Indiancreek's Avatar
Indiancreek
Hylamar made by Valco co.
Old May 17, 2012 | 09:28 AM
7T1vette's Avatar
7T1vette
NOT teflon tape. That is meant to seal water leaks....not petroleum leaks.
Old May 17, 2012 | 10:30 AM
billla's Avatar
billla
St. Jude Donor '14
+1; this is what I use for head bolts/studs.
Old May 17, 2012 | 10:44 AM
gkull's Avatar
gkull
I use teflon tape or even liquid teflon on all kinds of engine oil, tranny, and rearend AN fitting cooling lines. Even plugs and filler ports It is not recommended for fuel because the tape can be cut by the threads and it could end up in the carb or injectors
Old May 17, 2012 | 03:43 PM
7T1vette's Avatar
7T1vette
AN and other self-sealing joints don't require any sealant. So, using teflon on them is fine...because it has no effect on whether the joint seals or not.
Anyone can use anything for any purpose they want. But, teflon tape was designed primarily as a lubricant for pipe threaded joints so you could get a tighter joint. It also helps fill some minute gaps in the thread joint for water-carrying lines. There is a special [yellow] teflon tape for natural gas joints, but I don't know of any manufacturer that recommends using teflon tape with petroluem/fuel system.
Old May 17, 2012 | 05:18 PM
noonie's Avatar
noonie
Most modern tapes and pastes are both a thread lube and a sealant. Try and stay away from a silicone base.
Many different pastes and at least 5 different densities of PTFE tape. BTW, the colors aren't for compatibility, but for industry or building code compliance. green for oxy and yellow for nat gas.
Loctite has some very good choices and you can preseal the threads just like the bolts you buy,if you wish.
http://www.henkelna.com/us/content_d..._SSF437597.pdf
Some good info on one of them.
http://tds.loctite.com/tds5/docs/LOC...ACKSEAL-EN.PDF
To Head stud sealant
