Bittersweet post, finally a problem I can't fix
Old May 18, 2012 | 10:59 PM
larrywalk's Avatar
larrywalk
Veteran: Marine Corps
Originally Posted by Speedracer86
... I don't particularly have the means to drop the tank and clean out the sock, is there another way I could do it?
To replace the sock, one doesn't have to drop the tank. Simply remove the gas filler door, and the rubber neck around it. There is enough room to loosen the screws and pull the assembly out for replacement.
Late note: Sorry, it appears that this works for the '78 & later, but not '75-'77.
Old May 19, 2012 | 12:14 AM
Speedracer86's Avatar
Speedracer86
8th Gear
From what I can see there's barely enough room to get a wrench in there
Old May 19, 2012 | 12:33 AM
noonie's Avatar
noonie
77 should have the large oval assembly, too big.
Do a Mooser said. To test, jack the rear up a bit and with the line loose at the fuel pump you should get a lot of gas flowing thru the line once you get it started with a little syphon action.
Go from there.
Old May 19, 2012 | 12:53 AM
Ben Lurkin's Avatar
Ben Lurkin
St. Jude Donor '09
After that, test your fuel pump. Start the car and let it run for a minute to fill the fuel bowl. Shut it off and disconnect the fuel line, attach a rubber hose long enough to slip into a 2 liter bottle. Restart the engine and let it run for 10 seconds or so. You should have about a pint of gas in the two liter bottle if the pump is working properly.
Old May 19, 2012 | 09:57 PM
Speedracer86
8th Gear
I just had a thought, do you think that the alternator being bad would have anything to do with the problem? I've see the volt gauge dropping below 13 quite often in the past few days, just about the same amount of time this problem has gotten worse (It used to be about 70mph, now its 40)
Old May 19, 2012 | 10:21 PM
YANKEECORVETTE's Avatar
YANKEECORVETTE
If the lines turnout to be clear, you might have worn out cam lobe that the mechical fuel pump operates from. The pump most likely can keep up at lower demand. But when the engine is under a high fuel demand the pump can not keep up. If your engine has high hard miles with the original cam or fuel pump one or the other might be it. The quick way is go to a electric pump. To check the lobe and pump push rod means removing the pump and use a dial indiactor to check the stoke.
Old May 20, 2012 | 09:37 AM
YANKEECORVETTE
No it most like is not but it is worth it looking into.Break out the volt meter. First check the battery w/ the key off.Should be 12v. Strart the car volts, should go up. Race the engine around 2000rpm for short burst. See if it changes. Ignition systems uses only 9volts, but something else could be draining. A loose ground, bad connection, or a loose belt.
Old May 20, 2012 | 10:44 AM
superdave269's Avatar
superdave269
WOW! Alot of good advice. I bet I have had all of the problems that you guys told him to check for over the years(thank goodness not all at once). The first time I had a blocked muffler (because the cat fell apart ) I was stumped, never even heard of it before that. I did just have to change my tank meter because it was clogged up, reducing fuel from getting to the carb.
Old May 20, 2012 | 11:12 AM
63mako's Avatar
63mako
St. Jude Donor '08-'09
Not the alternator. You changed the filter. Since it is getting progressivly worse my bet is the fuel tank sock. Definetly sounds like a lack of fuel.
Old May 20, 2012 | 08:25 PM
my 76 ray's Avatar
my 76 ray
It could be electrical. Can you look at the volt gauge while the problem is occurring.
Old May 21, 2012 | 11:33 AM
cv67's Avatar
cv67
St. Jude Donor '05
Originally Posted by 63mako
Sounds like a fuel volumn issue. My guess would be one of the following in order of likelyhood:
1. Fuel filter.
2. Strainer sock in tank
3. Weak fuel pump
63split63 posted while i was slowly typing.
