1980 temp wont turn down
This vehicle was in North Carolina and not driven for the last 2 years. When I got it her to Ohio, temps were still cool and I switched the temp control to warm. All functioned as it should. Problem is now it wont turn back to cool. The lever slides fine, and the selector diverts air where it should, just always warm.
Any suggestions of where to start?
Thanks in advance for your input.
Chris
Lastly, there are a few sources for 'extraneous' heat getting into the cockpit: the kickpanel door(s) might not be sealing well nor opening/closing properly; the rear hood seal (if your year uses one) may be worn to the point that it no longer seals, thus allowing engine comparment heat to get fed directly into the cockpit air inlet (cowl area of right fender); and the all-too-familiar condition of exhaust pipe heat coming up into the passenger area from directly below.
To get a good handle on unwanted heat, you need to check out the heater control head to make sure it is working as intended and that activation switches mounted to it are doing their job. Also, the vacuum distribution manifold (mounted to the left side of the control unit) has good integrity...not broken and sealing well...and the vacuum lines are sending proper signals and those servos receiving the signals act appropriately.
There are lots of things that need to be checked out and actions that need to be taken to assure that unwanted heat does not get into the passenger area. Good luck on checking out your car's systems and successfully resolving your heating issues.
Thanks again
