TH 400 Issue....
Old May 20, 2012 | 11:15 PM
mrmagrath's Avatar
mrmagrath
Default TH 400 Issue....
Why would my TH400 shift down while going around sweeping bends at around 35MPH? Happens going both left and right. We're not talking sharp bends here either!
Old May 21, 2012 | 02:07 AM
pricesgarage's Avatar
pricesgarage
low fluid level or some one shimmed the filter so it will not float th400 filter will pivot
Old May 21, 2012 | 02:48 AM
mrmagrath's Avatar
mrmagrath
Thanks. I'm sure the fluid level is good. I've been meaning to do the filter for a few weeks now. I've had one sitting around for ages. It's a good excuse to get off my butt!
Old May 21, 2012 | 03:47 PM
JimT's Avatar
JimT
If you are going to pull the pan, go ahead and replace the detente relay/solonoid. This relay controls the kickdown action in the tranny (shifting down to second gear). The relay could be weak and the rocking of the car could be causing it to open or close.
Old May 21, 2012 | 11:32 PM
7T1vette's Avatar
7T1vette
The vacuum modulator could have a leak in the diaphragm and occurs more under load during turning. If oil gets into that vacuum tube, then the vacuum signal may not function properly. Or, there could be some mechanical malfunction in that modulator. In any event, I think the modulator is the problem.
Old May 21, 2012 | 11:44 PM
mrmagrath's Avatar
mrmagrath
Thanks 7T1vette. Your help is always appreciated!
Old May 24, 2012 | 06:32 AM
JimT's Avatar
JimT
Please let us know what you find, as this is a common subject here on the forum.
Old May 24, 2012 | 08:07 PM
mrmagrath's Avatar
mrmagrath
Sure Jim.
First thing I've noticed after reading the AIM, is that I'm missing the hard line from the trans to the intake. Bubba has rigged up a length of hose. Could that be a cause?
Old May 24, 2012 | 11:31 PM
7T1vette's Avatar
7T1vette
If the hose is collapsing when you let off the throttle in the turn, then no vacuum would pass to the modulator. Once throttle picks up again, it should shift OK. Yes, I think that might be your problem. If you want to Gerry-rig it to test for that problem, just get a length of inexpensive aluminum tubing and stick some hose on each end to make the intake & modulator connections. Duct tape it in place, if you have to, just for testing. Try it out and see.
Old May 24, 2012 | 11:36 PM
mrmagrath's Avatar
mrmagrath
Thanks 7T1vette. Makes perfect sense.
Shouldn't you be in bed at this hour? It's 3:35pm here in NZ. And we've just had a 5.2 aftershock to keep us on out toes!
To TH 400 Issue....
