Headlight short.
Old May 21, 2012 | 01:18 PM
curtis1512's Avatar
curtis1512
Default Headlight short.
78
When i turn on the headlights, even the running lights, the temp gauge goes all the way to the right. The lights work when this happens. I turn them off, the gauge goes back to reading the temp.
Curt
Old May 21, 2012 | 01:35 PM
my 76 ray's Avatar
my 76 ray
The temperature gauge works by being grounded to the engine block through the temperature sensor. I'm thinking that somehow the temperature gauge circuit must be getting extra voltage from the headlight circuit when the headlights are on.
What happens with the temperature gauge if you disconnect the wire to the temperature sending unit? Tell us what happens with the lights on and off.
Old May 21, 2012 | 02:01 PM
curtis1512's Avatar
curtis1512
I pulled the temp wire off. The Temp gauge went to the right. I turned on the lights, the temp gauge went even more right.
Old May 23, 2012 | 01:29 PM
curtis1512's Avatar
curtis1512
Any more help would be appreciated.
Old May 23, 2012 | 02:06 PM
RobbSalzmann's Avatar
RobbSalzmann
St. Jude Donor '12
My 76 Ray is pointing you in the right direction. However there isn't "extra voltage" being generated. You have loose ground in your headlight circuit somewhere, so the headlights are drawing the current they need through another path to ground (the temperature sending unit).
Old May 23, 2012 | 09:38 PM
my 76 ray's Avatar
my 76 ray
Is there any difference in the brightness of the headlights with the temp wire on and off?
Old May 24, 2012 | 07:41 AM
...Roger...'s Avatar
...Roger...
I would guess your dash gauge is loosing its ground when you turn on the lights.
Sounds like the dash gauge at the present is finding its ground via the instrument lights,when you turn on the lights the ground goes away and the gauge acts up.
Try removing the INST light fuse,if the gauge fails to work at all it was doing what I said above. Then you have go in and see why,probably a printed circuit issue.
To Headlight short.
