Need recommendations for engine upgrades
Old May 21, 2012 | 06:44 PM
bigge1014's Avatar
bigge1014
6th Gear
Default Need recommendations for engine upgrades
I recently inherited a 75 with the L48 engine, not sure what transmission but I believe it is all original. Besides basic repair work to keep it running, I believe everything on the car is original. It has been sitting for awhile so I plan to have the engine and transmission pulled and rebuilt.
I figured while doing this, I'd like to soup up the engine a bit. I will not be doing the work, a shop will. I am looking for ideas on things I can ask for to be added or changed out to help increase horsepower, torque, etc...
My overall budget is around $10,000. I'd rather not spend all of it on the engine and tranny as I'd like to do some other restoring of the car as well.
Thanks in advance for any suggestions.
Old May 21, 2012 | 08:13 PM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
The L48 really needs more than a couple of simple bolt-ons during rebuild to wake it up, so you might want to consider just setting it aside and installing a decent performance crate engine from a reputable source. JMO
Old May 21, 2012 | 08:16 PM
JimmyS5600's Avatar
JimmyS5600
Active Streak: 90 Days
Good advise. It usually costs more to rebuild that useing a crate
engine
Old May 21, 2012 | 08:42 PM
myko's Avatar
myko
I have to agree. I just bought an '80 and was pleased to find that it has the original motor with emissions/carb/everything stock. I already have an '80 that I rebuilt a 383 from a 4-bolt main block that I already had - thought I would save some money. I saved a bit but other than the experience it was not worth it.
Look at Jegs or Summit for some references after your shop gives you a quote. For around $4K you can have a 400HP engine delivered (eg. http://www.jegs.com/i/Blueprint-Engi...oductId=761056). That will give you plenty of cash and a LOT more time to work on the tranny and chassis to handle all that power!
Old May 21, 2012 | 09:05 PM
iokepakai's Avatar
iokepakai
Good advice given already.I have a 76 L48 that I upgraded.If I know then what I know now I would've gone the crate engine route.You'll be ahead with a good crate engine and install an OD trans while your at it.Having a 6spd manual is way more enjoyable to drive then a 3spd auto.
Old May 21, 2012 | 09:42 PM
johnt365's Avatar
johnt365
Getting the right combination is what you want. The motor,tranny and rear end all have to work well together. The motor itself has to have matched parts too. If you haven't spent the last 10 years reading Hot Rod or Super Chevy then a crate may be a good idea.
For the motor you need a set of small chamber heads to boost compression, a cam that has a low power band, an aluninum intake and headers. $3k ish with lifters gaskets and stuff.
If you get a cam that sounds like you got a cam then you probably want a different torque converter $200
Then do you keep those highway gears and switch to a 700-r4 so you can spin the tires or change the rear end or both.
Torque converter and gearing will make less HP feel more fun.
Old Feb 4, 2019 | 07:50 AM
Drothgeb's Avatar
Drothgeb
Never mind
Old Feb 4, 2019 | 01:06 PM
OldCarBum's Avatar
OldCarBum
Do your research on any create motor.
Make sure they are using "new" top quality parts and look for things like, forged pistons, forged cranks, rods, etc that are name brand components.
Watch out for comments like "reconditioned", "as good as", assembled in Mexico or China, etc.
If you purchase a cheap create motor, you get cheap.
You really need to do your research and just don't purchase one with a good warranty.
Also read the full warranty.
Most require that you return the motor to the manufacturer for them to diagnose the cause for failure before any warranty repairs are made.
I purchased a create motor from a well known builder about ten years ago.
The engine cradle failed during shipping and the motor was bouncing around inside the shipping create during shipment.
The manufacturer fought with the shipping company for over one year while I had a new battered motor sitting in my garage I couldn't use.
Be careful.
Old Feb 4, 2019 | 07:16 PM
rtruman's Avatar
rtruman
https://www.karlkustoms.com/p/350-HO-Deluxe-333HP-Crate-Engine-Chevrolet-Performance-19210007/1865/25?gclid=CjwKCAiAmO3gBRBBEiwA8d0Q4iQkmSK 7LbSw6IL509UGR2jnJtGNTPCbsI-qxujoBDLto-w61KK-7BoCbbYQAvD_BwE
How
did I do on this one already delivered
Old Feb 4, 2019 | 08:02 PM
jackson's Avatar
jackson
money better spent on this … yours is nice but flat tappet … this one essentially same but with roller cam-lifters & damper ...read through it delivered under $1600 ... for another $1K You
can add bigger roller cam and vortec intake and hi-lift springs&retainers And have local machine shop finish the fuel pump mount. Read it entirely under $1600 delivered .
https://www.ebay.com/itm/GM-OEM-NEW-...nA85:rk:1:pf:0
Old Feb 5, 2019 | 09:17 AM
rtruman's Avatar
rtruman
Good price for sure didn't want to deal with the non fuel pump issue.
Do you notice they didn't list HP ratings Thanks for the info
Old Feb 5, 2019 | 01:44 PM
jackson's Avatar
jackson
Of course.
That motor is Not marketed as a hi-po motor with lotsa hype … it's marketed as a OE replacement for a truck.
GM doesn't publish HP spec for replacement motors as that's part of hi-po ad campaign
No need to publish replacement motor HP spec as it's the same as OE and That is/was published.
If GM published all the tips & specs & potential this replacement motor has... that might help defeat the efforts of their Performance marketing crew.
This replacement motor is essentially a 350HO … but this has OE roller cam&lifters… and it's about $1000 LESS!
Local machine shop can finish pump mount for $100.
Old Feb 5, 2019 | 03:39 PM
cv67's Avatar
cv67
St. Jude Donor '05
Not bad for the money, that crate (jackson) is begging for a cam!Something even in the 2teens @050 would really wake it up.
Old Feb 5, 2019 | 10:34 PM
jackson's Avatar
jackson
Absolutely, slickest fix I see is swap to GM LT4 "Hot Cam" & LS6 springs & maybe 1.6:1 rockers. That's basically what yearone & blueprint do for around 400hp.
To Need recommendations for engine upgrades
